AC/Heater Control Faceplate Lighting
Is having a poorly lit heater control faceplate the norm for these C3's? Mine is a '74 so I don't know about other years. If its normal I won't dig any further. Maybe going LED for this control panel will brighten it up further?
Yep, those heater/AC controls weren't the brightest, that's for sure. When I restored my heater controls, I painted the inside of the bulb housing and the backside of the black faceplate white. I can now easily see the controller in the dark. I tried to snap a pic, but you know how it is taking pictures in the dark....kinda tough! This should give you an idea of the improvement though.
Dave
2. The bulb could just be old; incandescent bulbs dim with age.
3. The bulb/socket may not be fully inserted into the mounting hole.
4. The metal 'reflector', into which the bulb/socket is inserted, might be corroded or [mistakenly] painted. It must be clean and shiny for it to reflect enough light for that location. Even just the natural dulling of that surface over the years will have a significant effect.
Dave
You don't have to remove the control head at all if the problem is an incorrect bulb or an improper installation of the socket in the bottom of the control. If you determine that the problem is a matter of a dull reflector in the control head, you MIGHT swap out that bulb for a much more powerful, multi-element LED bulb. It will produce a lot more light AND it will not generate much heat. The downside will be that your 'dimmer' control on the lamp switch will have little affect on it; and if you dim the lights very much, that lamp will not illuminate.
Those downsides may be of little concern if you can just replace the bulb and get more light in that control head...without removing it.
When I took mine apart, there was a nice film on the plexi lens, suspected coming from smoking, spilled Coke, etc.
Cleaned that up (top and bottom) and it improved somewhat, but still could be brighter.
If you go to eBay and search "LED bulbs auto 1816" or "LED bulbs auto 1895" you will likely come up with LOTS of choices for such bulbs. Also, many auto parts stores are carrying LED replacement bulbs for the old incandescent lamps. Pick a bulb that has several LED elements around the body and at the end for best illumination. If you buy from a local parts store and it doesn't work or do the job you think it should, you can take it back. Not that easy with internet purchase.
