Need Help
Old Jul 22, 2017 | 02:31 PM
jonsz06's Avatar
jonsz06
Default Need Help
:I'am restoring a 1973 vette,I have replaced all wiring from dash forward I have juice to the starter switch, but car will not start went I turn the key nothing. I have no dash lights but I have courtesy lights. seens I have no power to neutral switch
Old Jul 22, 2017 | 09:14 PM
MelWff's Avatar
MelWff
not sure what you mean by starter switch, there is an ignition switch and a starter solenoid.
Do you have 12+ volts at the starter solenoid large terminal?
Do you have the two smaller wires on the solenoid corectly connected and have not reversed their positions?
when the key is turned to start do you get 12 volts at the smaller wire on the S post of the solenoid?
Old Jul 22, 2017 | 10:15 PM
jonsz06's Avatar
jonsz06
Thanks I will check that. sorry I meant ignition switch.
Old Jul 24, 2017 | 11:36 AM
jonsz06's Avatar
jonsz06
I do not have power at the s post. does the steering column have to be grounded? what should look for?
Old Jul 24, 2017 | 11:54 AM
Alan 71's Avatar
Alan 71
Hi j,
On 4-speed cars the clutch pedal must be depressed in order for the engine to start.
The clutch pedal arm operates a rod that controls the clutch safety switch.
Have you checked that it's in place, connected, and the clutch arm is cycling it?
Regards,
Alan
Old Jul 24, 2017 | 01:38 PM
Peterbuilt's Avatar
Peterbuilt
The Yellow wire goes to the solenoid terminal closest to the fender.
The Purple wire connects to the small terminal closest to the block.
The purple has 12 volts only with the key in Start.
The Black is a ground and connects to a bell housing bolt.
https://docs.google.com/viewer?a=v&p...ZTM0ZDc1MWM5Ng
Old Jul 25, 2017 | 01:35 PM
jonsz06's Avatar
jonsz06
Thanks for the info. I am not using the coil. I replaced the distributor with a built-in coil. Do I have to rewire the system differently?
Old Jul 25, 2017 | 04:42 PM
Peterbuilt's Avatar
Peterbuilt
Yes!
Find to two wires that were connected to the + terminal on the original coil and tape them up so they don't touch anything. You don't need them any more.
Quick fix:
Your HEI distributor needs a new wire to be run from the FUSE box IGN terminal to the distributor.
Long term fix is to separate the fuse box and replace the resistor wire.
This has nothing to do with a 'no start problem'.
Old Jul 26, 2017 | 10:25 AM
jonsz06's Avatar
jonsz06
Thanks for the infor. I have no power at the neutral safety switch, so I will have trace the wire,
To Need Help
