Ignition coil capacitor wiring
Old Jul 26, 2017 | 05:32 AM
D0wnunder73's Avatar
D0wnunder73
4th Gear
Default Ignition coil capacitor wiring
I have a 72 small block with manual transmission, where does the ignition coil capacitor wire too? Is it the + or - terminal on the ignition coil?.
Thanks in advance
Old Jul 26, 2017 | 06:16 AM
Alan 71's Avatar
Alan 71
Hi D0,
The radio noise capacitor connection is typically at the positive (+) terminal on the coil.
Regards,
Alan
Old Jul 26, 2017 | 06:17 AM
GunPowder's Avatar
GunPowder
Thanks in advance
to plus on the coil (if the cabling is correct, black wire from distri goes to -), but it does not really matter (there are a lot of threads regarding the correct and reverse coil wiring)
To Ignition coil capacitor wiring
