Steering wheel clocking while driving
Old Aug 8, 2017 | 11:37 AM
jlpskydive's Avatar
jlpskydive
Default Steering wheel clocking while driving
I have 78 SAE L82 and while I dive down the street to keep it straight the wheel is 25 degrees to the left. I thought at first that the locksmith when he replced the wheel he put it on wrong, but as it sits in the garage the wheel and the tires are both centered up nicely. What could be the cause of this. BTW the car only has 5,700 miles on it.
Old Aug 8, 2017 | 11:45 AM
Mr D.'s Avatar
Mr D.
Front end alignment BUT did you verify he installed the steering wheel correctly.
Old Aug 8, 2017 | 11:48 AM
jlpskydive's Avatar
jlpskydive
I'm pretty sure he did, when its sitting still, everything is lined up perfectly. Also, everything works as it should in the column. The previous owner (my dad) lost the keys. That's why it was apart.
Old Aug 8, 2017 | 11:50 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
It could be one screw hole off on the installation.
But other things might be at play too.
Check your tire pressure, one could be low and causing this... then check the screw hole alignment of the steering wheel and then the alignment.
Willcox
Old Aug 8, 2017 | 11:57 AM
jlpskydive's Avatar
jlpskydive
Willcox
Thanks the tires were just replaced and it did it on the old set also. I will check screw alignment shortly. Do I need a wheel puller to get it off or is it just the screws?
Old Aug 8, 2017 | 12:10 PM
0Willcox Corvette
Former Vendor
nope... just keep track of how the horn button and the upper contact, shims screws come out... Take a picture first, it'll save you some time when you go back.
Old Aug 8, 2017 | 12:12 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Slack in the steering box causing the problem on roads with "built-in" slope?
Old Aug 8, 2017 | 12:59 PM
bradleyb66's Avatar
bradleyb66
Does it 'pull' to the right? If it's pulling, and you need to turn left to compensate, then I'd guess alignment. If it drives straight down the road, but the wheel is just not centered, then I'd guess the steering wheel was off by one hole.
Old Aug 8, 2017 | 02:43 PM
jlpskydive's Avatar
jlpskydive
Not much slop in the steering.... Yet
Not really pulling, I just pulled the wheel and put it where I think is center. I'll know in a few minutes whether I did it right or not, but at least my horn and locking collar still work.
To Steering wheel clocking while driving
