AC compressor brackets...?
Old Aug 11, 2017 | 10:59 AM
ChevyVetteguy75's Avatar
ChevyVetteguy75
Default AC compressor brackets...?
Hey All,
I'm doing a rebuild of my engine on my 75 Corvette. I added a few performance parts to add a little hp over stock. One addition was roller rockers which means taller valve covers.
My problem:
The ac compressor wont fit with the stock ac brackets with the taller valve covers. Has anyone done this type of upgrade and bought an AC bracket that connects to stock location but extends long enough to clear the valve covers? If so, where did you get the bracket and which one was it?
I looked around on Summit, they have a ton of brackets but none mention extending past stock location so I'm not sure if they'll work.
Thanks to all who have an answer.
Old Aug 11, 2017 | 01:12 PM
henrikse's Avatar
henrikse
Never heard of other bracket but shouldn't be hard to make one or have a machine shop make one. It is only the front bracket with slot to adjust you need? I have a chrome one and finned valve covers but mine fit.
Old Aug 11, 2017 | 05:21 PM
REELAV8R's Avatar
REELAV8R
Are you committed to using tall valve covers? Have you tried to get the belt on the alternator on the other side with those tall covers yet?
There are spacers that put your stock covers just 1/4" higher to clear the roller rockers. Some guys double up the valve cover gasket and use rubber over metal gaskets to to so.
I bought roller rockers that would fit under the stock height covers for just the reason you are struggling with now, that and the difficulty with the alternator belt as well.
Old Aug 11, 2017 | 05:40 PM
REELAV8R's Avatar
REELAV8R
https://www.summitracing.com/parts/i...iABEgKb9fD_BwE
These are the spacers I was thinking of. 3/8" I guess not 1/4". So these plus gaskets may put you more in the range of 1/2" to 5/8" higher on stock covers.
Old Aug 17, 2017 | 03:51 PM
ChevyVetteguy75
Hey, thanks for the idea. I found a extended bracket on Summit racing from Vintage Air. I havn't put it on yet but it should work.
To AC compressor brackets...?
