Help with wiper adjustment
Old Aug 17, 2017 | 08:41 AM
Silver72's Avatar
Silver72
Default Help with wiper adjustment
ok, need some help w/the '72.
I cannot get the passenger wiper blade to park far enough for the door to close. We have tried adjusting everything we can think of. We are confident the wiper arms are correct. The wiper arm spring appears to be working like new. Blade insert does not rest flat on the window though. Driver's side parks correctly and blade insert lays flat on window. We've adjusted the 4 nuts on the wiper trans assembly to no avail. We have been contemplating modifying the wiper door relay bracket (slotting it and moving it down so the arm will lower) I'd like to avoid bubbying it up though.
I welcome any suggestions (besides don't drive in the rain). :-)
Thanks,
Steve
Old Aug 17, 2017 | 08:56 AM
Alan 71's Avatar
Alan 71
Hi Steve,
Are you saying the 'lever' on the right-side wiper transmission isn't pushing the plunger far enough for the switch to send the vacuum signal to the relay to close the door?
Have you tried using screw 'A' to adjust the angle of the arm and blade to get it to attempt to park fully?
Regards,
Alan
Screw 'A' changes the angle of the wiper arm extension and thus how the blade 'parks'.
Old Aug 17, 2017 | 03:37 PM
Silver72's Avatar
Silver72
Originally Posted by Alan 71
Hi Steve,
Regards,
Alan
The wiper arm is depressing the switch and we have tried adjusting the screw. We are wondering if the wiper blade (not the blade insert) may be the problem - especially as it is not sitting on the window flat. When the arm is parked it depresses the switch but it can be manually pushed a little bit further. There seems to be very few adjustment options. Very perplexing.
Old Aug 17, 2017 | 04:23 PM
MelWff's Avatar
MelWff
below is a document from Willcox showing how to adjust the arms
http://repairs.willcoxcorvette.com/1...rm-adjustment/
To Help with wiper adjustment
