Hi 71,
I believe you're referring to the opening for the electrical connection for the temperature sensor that is part of the 71
Combined Emission Control (CEC) system.
Regards,
Alan
This is the sensor in the head the wire connects to.
Hi 71,
The wire is actually a long pig tail that connects to a short lead that exits the engine harness around the rear of the right side valve cover.
Is that wire and connector still present in the engine harness?
Regards,
Alan
This is the lead and connector at the engine harness.
Introduced in 1970, the Transmission Controlled Spark (T.C.S.) System controls exhaust emissions by eliminating vacuum advance in the lower forward gears while at operating temperature.
item # 663167 (the harness I was looking for) at Corvette Central
Hi 71,
The system used in 1971 was called the Combined Emission Control system. (CEC)
The Temperature Controlled Spark, (TCS) system was used in 1970 and 1972.
One of the differences in the hardware for the system was the placement of an electrically operated vacuum solenoid mounted on the right front of the carburetor.
Both systems required a temperature controlled switch… thus the sender in the right side cylinder head.
Regards,
Alan
The 71 CEC solenoid and bracket on the carburetor.
Thanks again Alan, I'm still confused, but I found the wire I want to replace, all this is over my head, so I'm just happy making it correct regardless of its purpose
Maybe you thought YOU were wrong, but Alan is never wrong!
He's got the knowledge, photos of his very sweet '71, and willingness to help other Vette Heads out. Way to go Alan
