What do these vent control cable brackets attach to?!?
Old Aug 15, 2017 | 02:52 PM
gguillot's Avatar
gguillot
Default What do these vent control cable brackets attach to?!?
I've searched high and low on the forum, but have not been able to find a definitive answer on what these plastic cable brackets for the air vent controls on a non-A/C car connect to. I have a '72. I had to use the shift plate repair kit on the center console since the old plastic mounting points broke off long ago - I'm wondering if I removed the mounting points for these as well. They definitely don't seem to line up with the upper mounting points for the shift plate - readily seen on the metal bracket in the attached picture.
Anyone run into this before? I don't understand why this is stumping me
Old Aug 15, 2017 | 03:44 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Hmmmmmm....kick panel vents?
EDIT: ooops...misread your question
Old Aug 15, 2017 | 03:48 PM
Alan 71's Avatar
Alan 71
Hi gg,
They each mount to small bracket on the underside of the shifter console with a small screw.
Regards,
Alan
Note this photo shows a repair method for the shifter plate screws too. Disregard those plates.
Old Aug 15, 2017 | 03:52 PM
gguillot's Avatar
gguillot
Originally Posted by Alan 71
Hi gg,
Regards,
Alan
Thanks Alan. Do you know if it was a separate bracket, or part of the underside of the console? I know there is a reinforcement bracket underneath there - maybe that's it.
Old Aug 15, 2017 | 03:53 PM
Alan 71's Avatar
Alan 71
Hi gg,
I added a photo showing the brackets.
Regards,
Alan
Old Aug 15, 2017 | 11:29 PM
gguillot's Avatar
gguillot
Hi gg,
Regards,
Alan
Alan!
Thanks!! Your picture is worth a thousand words! I also have those shifter screw repair plates on mine too, so its even more appropriate.
Many thanks!
To What do these vent control cable brackets attach to?!?
