What should I work on while the engine is out?
Old Aug 23, 2017 | 09:35 AM
DAC516's Avatar
DAC516
Default What should I work on while the engine is out?
I have the engine out of my '69 for a re-ring. I'm looking at all of that space and trying to prioritize projects. Of course, I will clean the firewall and maybe change the power steering hoses. What else would be convenient while the engine is out? Maybe replace headlight vacuum hoses?
Old Aug 23, 2017 | 12:16 PM
bashcraft's Avatar
bashcraft
Are the hoses leaking? If not, why would you change them?
Old Aug 23, 2017 | 12:33 PM
DAC516's Avatar
DAC516
Just preventative. They look original.
Old Aug 23, 2017 | 12:39 PM
540 vette's Avatar
540 vette
I change everything. If it works or not. I change hoses, vacuum lines, brake lines. Original or not. Then everything is mine. And I know it should work.
Old Aug 23, 2017 | 12:54 PM
CPTCroaker's Avatar
CPTCroaker
I would have said firewall right off the bat, but looks like you are going to take advantage of that already. How about taking this opportunity to inspect and refresh the main vac reservoir. That thing will be a million times easier to get out now and patch up any potential leaks.
Old Aug 23, 2017 | 02:17 PM
Alan 71's Avatar
Alan 71
Hi DAC,
I wouldn't replace the vacuum hoses just for the sake of changing them.
If anything, cut 3/8" off each end of each hose which give the hoses a fresh sealing surface at each connection.
If you decide to change the hoses, and they are indeed the originals, I'd gladly buy them from you.
Regards,
Alan
Old Aug 23, 2017 | 03:06 PM
Gold Dragon's Avatar
Gold Dragon
Inspect the chassis & frame rails. Excellent opportunity to clean and detail.
Old Aug 23, 2017 | 03:30 PM
C3 Stroker's Avatar
C3 Stroker
Considering a Borgeson steering upgrade?......Now would be a good time.....
Old Aug 24, 2017 | 05:36 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
front suspension bushings, get the radiator flushed and preassure tested. clean and paint the hinges and the hood latches. check the motor mounts for tearing. pressure wash the transmission tunnel and insulate it. clean and paint the driveshaft and replace the u joints. inspect the body mounts, look for any stress cracks in the fender areas. clean the light assemblies.......
Old Aug 24, 2017 | 08:34 AM
NRAROX's Avatar
NRAROX
Repair that dent in the cross member where Bubba raised the car with a floor jack. Clean and mend every hose and wrapper, sealing with nu-vinyl. Replace the A-arm covers if torn. Inspect the firewall grommets, verifying they are there and secure, then put a bright light in the passenger compartment with the room dark to verify you got it right. Clean and paint the brake fluid reservoir. Restore the hood connection pin assemblies and inspect the hood e release cable. Rebuild the steering linkage and power hydraulics (if applicable).
Old Aug 24, 2017 | 11:52 AM
Rescue Rogers
good idea, mine trashed when I first got my vette and I made it worse
To What should I work on while the engine is out?
