1982 fan
Aug 30, 2017 | 11:35 PM
1982 fan
I want to take out the factory clutch fan .and put in a fan that would be run from the wires from the smaller auxillary fan.are thes wires heavy enough to do the job..The sending unit has all ready been changed .to 180 degree.
Aug 31, 2017 | 12:04 AM
I assume the factory ran a relay on it. But i would check to be sure,
An electric fan needs a relay
Aug 31, 2017 | 12:27 AM
I have found the wires that bring power to the fan but I don't know where the relay is.yet.
Aug 31, 2017 | 08:38 AM
Believe it or not there is no relay.
Aug 31, 2017 | 09:43 AM
I may have to run all new wiring .new fan new wires no worries.Thanks
Aug 31, 2017 | 10:58 AM
No kidding rat?
Yeah, an electric fan needs a relay, this was just gm half assing something to be cheap,
Ive said many times just because its factory doesnt make it best.
Aug 31, 2017 | 12:08 PM
Quote:
No kidding rat?
Yep. That fan is wired directly to the sending unit. There is a fuse for it in the fuse box.
Aug 31, 2017 | 12:30 PM
Both my 81s had the axillary electric fans but i just went right to rewire,
I had on one that adjustable hayden style switch feeding a relay then on the second one i just had a cockpit switch feeding a relay,
Even that little stock electric fan is a pretty good load on a temp switch, i guess gm knows best,
Aug 31, 2017 | 12:52 PM
Quote:
Originally Posted by
The13Bats
Yes it is. It uses a 30 amp fuse.
Sep 1, 2017 | 09:26 AM
do the new fans draw as many amps as the old factory fans.30 amp fuse is a lot.
Sep 1, 2017 | 11:04 AM
terry82
Some large electric fans spike pretty high on start up then settle down while running,
My issue is even with correct gauge wire i wouldnt like all the power going through the little temp switch, i would have better peace of mind using a relay
Sep 1, 2017 | 08:29 PM
I think a relay is a good idea and maybe good insurance of not having a problem .
Sep 1, 2017 | 10:26 PM
Quote:
I agree.
Simple enough to add.
Piece of mind.
