C3 aftermarket Steering Columns
Old Sep 4, 2017 | 03:39 AM
ariba's Avatar
ariba
Default C3 aftermarket Steering Columns
Hello everyone
I am looking to change my stock 77 steering it does not have tilt and no Telescoping. The most important thing for me is the tilt if the telescoping comes with it, it will be a + for me. my budget is less than $350.
Just to make sure all that I find they dont have the switch for the wipers
I did find some do they work? and any suggestions? open for all opinions.
https://www.summitracing.com/parts/s...AaAtA0EALw_wcB
http://www.speedwaymotors.com/Standa...ain,67289.html
http://www.ebay.com/itm/331966166597?ul_noapp=true
Old Sep 4, 2017 | 07:42 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by ariba
...any suggestions? open for all opinions...
Have you considered a used 77 tilt/tele column? Post a Want To Buy in the parts forum.
Old Sep 4, 2017 | 06:43 PM
Mewn's Avatar
Mewn
The last time I looked into this, the options were much more expensive. I ended up rebuilding my stock column but it is very tired and needs replaced.
A new column is on my to do list. Please post progress pics!
Old Sep 4, 2017 | 06:57 PM
wendellp601's Avatar
wendellp601
What are you planning to use for an ignition switch if you go with these options?
None of them have one.
Old Sep 5, 2017 | 12:40 PM
Richard Daugird's Avatar
Richard Daugird
I'd like a tilt-tele with no key.
Old Sep 6, 2017 | 05:42 PM
Sacred Steel's Avatar
Sacred Steel
Be careful with those no-name columns. They can be junk. My father bought one for his 38 Pontiac and it's junk. It feels like its going to come apart at anytime. He has the one with the ignition and he had to replace it three times within two years. The gear shift lever is loose and rattles. He hates it and regrets putting it in. Do what you want but I would save the money and get an IDIDIT or Flaming River. Thats just the my opinion though others may have had good luck with them.
Old Sep 6, 2017 | 11:07 PM
ariba's Avatar
ariba
For me no problem if I add a red start push button. It's a restomod.
Old Sep 6, 2017 | 11:12 PM
ariba's Avatar
ariba
I wanna make sure that any one tryd one of those? and was it a good result
Old Sep 7, 2017 | 12:15 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
I bought an IDIDIT tilt column/unpainted steel/turn signals/emergency flasher.....it has worked well for 7 years in my '34 street rod.
Old Sep 8, 2017 | 11:34 PM
ariba's Avatar
ariba
Thanks bro is it this one?
https://www.summitracing.com/parts/i...xoCCucQAvD_BwE
Old Sep 9, 2017 | 01:01 AM
Priya's Avatar
Priya
The thing I was surprised to hear is that these aftermarket steering columns don't have to meet automotive safety standards and be collapsable in an accident as American cars have had to be since 1967. I would definitely look at getting a used 77 tilt/tele steering column for that reason alone.
To C3 aftermarket Steering Columns
