Headlight door height
Old Sep 7, 2017 | 09:50 AM
75L82Squeak's Avatar
75L82Squeak
Default Headlight door height
Guys,
I have a issue with my passenger side headlight door (75 coupe). It doesn't go up high enough to remove the painted bezel and thus I can't remove the 2 headlights. It's about 1/4" lower than the drivers side door in the up position. It sits in its opening ok and it is good when closed. It just doesn't go up high enough.
I did search on the forum and read quite a few posts about adjusting the height but I'm not certain which of the adjustments will work for door height adjustment.
Do I just screw out the clevis until I get the needed height or do I loosen the 2 screws that hold the bracket (item 1 page 381 assy. manual) and move it until I get the needed height? Or is there another method? Will that mess up the door opening location?
Old Sep 7, 2017 | 10:13 AM
jhudec's Avatar
jhudec
Is the stop on the outer side of the headlight mis adjusted keeping the headlight from opening all the way?
Old Sep 7, 2017 | 10:19 AM
75L82Squeak
No. There is a gap of about 1/16". I've turned that screw to increase the distance and that didn't help didn't help the height issue.
Old Sep 7, 2017 | 10:31 AM
jhudec's Avatar
jhudec
I would disconnect the actuator and see if it then opens all the way.
Old Sep 7, 2017 | 10:40 AM
75L82Squeak
I'll give that a try and see what happens.
Old Sep 7, 2017 | 11:26 AM
75L82Squeak
I removed the 2 springs and pin through the rod clevis while the cover was down. I then pushed up the cover and checked the height. It seems to be the same as it was. It didn't change anything. The the stop on the outer side of the headlight is in the same place also.
Old Sep 7, 2017 | 11:33 AM
jhudec's Avatar
jhudec
Maybe post a pic?
As you know the headlight should open all the way and kind of snap into place.
Old Sep 7, 2017 | 11:59 AM
75L82Squeak
The headlight does snap into place. Just not in the right place?
Here's some pictures. There isn't any screws in the top of the bezel. That's why I'm holding it in the pictures. If you want others I can get them.
Old Sep 7, 2017 | 12:10 PM
jhudec's Avatar
jhudec
Sorry, the pics should be from below to show if the mechanism is fully extended or not. When you open the headlight does it feel as if it snaps into place when it reaches the end of travel?
Old Sep 7, 2017 | 12:17 PM
75L82Squeak
Yes. When I pushed the cover up, it did snap into place when it reached the end of its travel. I'll take some photos from underneath with the clevis pin out and post.
Old Sep 7, 2017 | 12:43 PM
Dave J's Avatar
Dave J
This is the critter you need to adjust to get the headlight door to open up a little more. Headlight actuator bracket is what it is called. Just back off the bolts a couple of turns and it should move. The slots are there for any adjustment needed.
Old Sep 7, 2017 | 12:49 PM
75L82Squeak
Here's those pictures.
Old Sep 7, 2017 | 01:47 PM
75L82Squeak
When I move this bracket will it mess with door location in the opening?
Last edited by 75L82Squeak; Sep 7, 2017 at 04:10 PM. Reason: remove unnessary text
Old Sep 7, 2017 | 01:55 PM
jhudec's Avatar
jhudec
The only other suggestion that I have is to loosen the 2 front bolts of the headlight support bracket. There is one bolt on each front side of the headlight support that bolts through the bottom front bumper support. Loosen those 2 bolts and it should give you enough play to push the headlight assembly up higher. It will only be able to move up higher as much as you loosen the bolts.
Old Sep 7, 2017 | 04:35 PM
Bikespace's Avatar
Bikespace
I ran into the same issue. I posted my solution here:
https://www.corvetteforum.com/forums...ght-bezel.html
There may be better solutions.
Old Sep 7, 2017 | 06:38 PM
Dave J's Avatar
Dave J
In a word, No. This adjustment is just for the up and down pendulum like door motion. It has nothing to do with the left/right, forward/back etc. It would help to temporarily remove the springs, but I've done it with them still attached. You may need to re-adjust the clevis, but I doubt it.
(Reference; 1970 Chevrolet Chassis Service Manual; Electrical - Body & Chassis - Section 12-3)
Old Sep 7, 2017 | 07:07 PM
DUB's Avatar
DUB
Also keep in mind the bracket on the side of the headlgith door that has the stop bolt that is adjusted.
It needs to be removed because simply adjusting the bracket shown in the post#13 will allow the door to come up higher...but NOT if the side bracket is stopping it.
DUB
To Headlight door height
Old Sep 7, 2017 | 08:08 PM
Bikespace's Avatar
Bikespace
Exactly. You can see the stop bolt in the third image (or the one DUB replied to). It may be easiest to remove it, keeping the setting. That's what I did on the second headlight. No need to remove springs, or adjust brackets, at least in my case, but that bolt had to come out. I removed the turn signal grille to get better access.
EDIT: Nevermind. This didn't work for the OP. I should have read the thread more carefully.
Old Sep 7, 2017 | 08:52 PM
Dave J's Avatar
Dave J
Hi Dave,
Good One!
I'm not sure if I'd EVER have remembered the adjustment available in that bracket's location.
Thanks!
Regards,
Alan
The above was posted in this thread;
https://www.corvetteforum.com/forums...ht-height.html
OP had already adjusted the stop out as posted
Old Sep 8, 2017 | 08:54 AM
75L82Squeak
I'll move the bracket and post the results.
Thanks to all. It's greatly appreciated!!!
