Pulled the body off my frame.
DUB
Mike
Mike
I am using relays to send power to the pump. One will run the power through a 2 ohm 50 watt resistor. The other relay will bypass the resistor and and send full voltage to the pump. It will be actuated by the original TH400 kickdown switch that is no longer used because I have a 700R4. I have the switch set so it will power the bypass relay at about half throttle.
I also am running through an oil pressure safety switch so that if my engine loses oil pressure or dies the fuel pump is shut off. I am running a wire from the starter solenoid to give current to the system during cranking.
Mike
I have never had to add more coolant after using this method and any possibility of an air lock is eliminated. I've never had a leak or failure from one of these adapters either.
Mike
The front was a little more work going from one side of the car to the other and then under the car and also under the hood. I didn't get as much caster as I wanted. I was hoping to get 6 degrees, but only ended up with 5 degrees. I set the front camber at negative .25 degrees as well as the rear. If I would kick the camber a little more negative I could get a little more caster. I wish I had spread my shock towers a little while I had it down to the bare frame. They were only sagged in about 1/6" total both sides, so I didn't do it. My VB&P tubular a-arms with offset crossbars helped get the 5 degrees, but I don't think you get as much caster added with them as they claimed. These are the a-arms I beefed up with some triangulation using moly tubing.
I am just going to be driving on the street for now, so I was fairly conservative with my alignment specs.
Front
Toe 1/16" in.
Camber .25 degrees negative.
Caster 5 degrees positive.
Rear
Toe 3/16" In.
Thrust angle dead on straight with front.
Mike
I had plans to post a lot more of my work here, but got a little lazy. I'll put more on the thread below later.
Link to my body off. https://www.corvetteforum.com/forums...-my-frame.html
Mike
Video running. iPhone sound doesn't do it justice. https://www.facebook.com/mike.roland.925/videos/2641517382555317/
<me
