Cruise Control
Old Sep 23, 2017 | 10:14 PM
jack mac's Avatar
jack mac
Default Cruise Control
Hey Guy's...need help ...trying to find a.."servo"..for the cruise control..on this 77...thanx much,,,
Old Sep 24, 2017 | 07:33 AM
LenWoodruff's Avatar
LenWoodruff
Is that the one that is on the manifold to control the throttle opening?
Old Sep 24, 2017 | 12:48 PM
SwampeastMike's Avatar
SwampeastMike
They haven't been made in years. When looking for one I found an old post by someone saying he probably found the last "new" (new old stock) one in the world.
The good thing is that many V8 GM cars from the 70s and 80s used a very similar servo. The one I found was NOS intended for a Chevy Nova. The mounting tab at the front was different but all I had to do was shorten the connecting linkage.
Old Sep 24, 2017 | 01:47 PM
jack mac's Avatar
jack mac
Thanx..Mike..i will keep lookin...for something....
Old Sep 24, 2017 | 02:21 PM
bmotojoe's Avatar
bmotojoe
If you're looking for a servo that will mount to your current 77 bracket 1977-1978 and some early 1979 corvettes servos had the metal backing and securing nut. Later servos had plastic backs that excepted 2 self tapping style screws for mounting. Completely different brackets. Unless you find a 77 servo you will have to modify the ball and chain setup to connect to your cable. If you find a servo, the 77 service manual says servo must hold 14" of vacuum for one minute, any less is considered defective.
Old Sep 24, 2017 | 02:26 PM
7T1vette's Avatar
7T1vette
Functionally, about ANY GM cruise vacuum servo will do the work. But, you may need to adapt it for mounting and to rig the connection to your throttle cable. So, get something from that vintage of GM vehicle....it doesn't need to be from a Corvette.
Old Sep 24, 2017 | 02:27 PM
jack mac's Avatar
jack mac
got it...14" for 1 min...found a servo for 78....will make it work...Thanx Much...
Old Sep 25, 2017 | 08:06 AM
LenWoodruff
Can you show pictures of the new servo for reference?
Old Sep 25, 2017 | 01:35 PM
bmotojoe's Avatar
bmotojoe
Len,
The 1977 model servo mounting bracket is located along the driver's side inner fender forward a little of the steering gearbox, your 1978 servo brackets are bolted to your intake and head. Here is a link to a forum members Late 1979-1981 brackets and servo. This setup will work on the 78 but not correct. Anytime you inquire about a used servo make sure it will hold a vacuum as described above.
https://www.corvetteforum.com/forums...g-bracket.html
Old Sep 25, 2017 | 03:09 PM
LenWoodruff
Len,
Thanks for the link. Fortunately mine on my 78 still works. I was just looking down the road for replacements.
To Cruise Control
