Door panel question.
Old Oct 9, 2017 | 04:00 PM
Team Evil's Avatar
Team Evil
Default Door panel question.
I want to class up my '74 interior a bit and am looking around for a set of the upper door panel "wood" trim pieces. Are they wood grained vinyl contact "paper" or possibly plastic fake wood inserts?
Thank you—
Old Oct 9, 2017 | 05:35 PM
SwampeastMike's Avatar
SwampeastMike
It's actually genuine wood veneer with a paper backing. Teak was commonly used. While it's produced in large rolls you can buy small quantities of such veneer from the likes of Rockler Woodworking.
Believe-it-or-not the wood trim that most call "fake" in cars both older and new is in many cases veneer. Even the wood in Rolls Royce cars (at least those made in the last few decades) is veneer.
If you decide to use wood veneer look for UV resistant lacquers for the top coat. DO NOT use ordinary polyurethane as it has very little UV resistance. Our dear EPA has declared the best lacquers too much of a hazard for "regular" people but since there is no comparable substitute they're now an "industrial" material that is difficult to purchase.
Old Oct 9, 2017 | 05:54 PM
Team Evil's Avatar
Team Evil
Thanks for the info ! I must have found the only wood grained insert in the world for sale with wrinkling shrinking contact paper rather than real wood:
http://www.ebay.com/itm/Corvette-OEM...53.m1438.l2649
I have a couple of rolls of burl veneer, thought that I would use it on the door accent pieces and buy a new $20 shifter console wood kit just to use it as a template for cutting new veneer. The cheap shifter console kits have a metal backing that would just be great as a template, then offer it back up for sale to someone who wants to go stock.
At least that's the plan for now, still have to find a pair of door inserts with decent aluminum surrounds.
Old Oct 9, 2017 | 06:32 PM
SwampeastMike
Those inserts are genuine wood veneer with a paper backing. The "wrinkling and shrinking" is most likely due to adhesive failure between the veneer and the substrate.
Old Oct 9, 2017 | 07:05 PM
Team Evil's Avatar
Team Evil
Just re-read the ad copy for that insert, it says," The panel has a poorly done faux (vinyl printed) woodgrain insert." That explains the shrinkage and wrinkles. I was HOPING that it wasn't the factory veneer, lucky for my plans, it isn't !
To Door panel question.
