Measurement Needed. Please!!!
What I need is the measurement that shows in my photo.
The dimension is 4-9/16" on my 71 column.
It looks like your's may be collapsed just a little bit.
Could that be?
Regards,
Alan
Perhaps this photo will help you in determining how far the shaft typical extends into the coupling.
And how the coupling seats on the steering box shaft (which affects how it seats on the steering shaft.
Could that be?
Regards,
Alan
Mine is at 4-1/8 and according to a paper that Jim Shea wrote all columns from 1967 on were designed to collapse and absorb energy in a severe front end collision. In addition, the paper stated that prying on the shaft might also collapse the shaft back into the column.
I was replacing my reverse lockout cable on my recently purchased 72 when I noticed the column issue. Thanks for the photos.
Scott
FYI: The above might not be the correct method to fix the problem.
Thanks Doorgunner
