Removing ign switch on '71
Old Oct 20, 2017 | 09:35 AM
sc2dave's Avatar
sc2dave
Default Removing ign switch on '71
Is there an easy, quick way to either remove unlock the steering lock on a '71? Reason i ask is i'm finally!!! getting that '71 I've been writing about and I need to turn the steering in order to move it around the rear of the house to the front and then into my backyard from the alley. Even if it means damaging the lock mechanism.I need to have car out by 4 this afternoon.Quick responses will be GREATLY APPRECIATED! Forgot to mention that I don't have a key, for either the ign or the fuel tank.
Old Oct 20, 2017 | 09:42 AM
Alan 71's Avatar
Alan 71
Hi sc2,
I believe if you remove the transmission lock cable at the steering column lever, and hold the lever 'up', the steering wheel will be free to turn.
Regards,
Alan
Old Oct 20, 2017 | 09:47 AM
sc2dave's Avatar
sc2dave
Thanks Alan. Is this right under the steering wheel area? I'mnot where the car's at right now. I'm still new to Vettes, that's why I ask. Thanks again.
Old Oct 20, 2017 | 09:54 AM
Alan 71's Avatar
Alan 71
Hi sc2,
Look in the engine compartment below the master cylinder.
Regards,
Alan
I'm having second thoughts if this will do it. But try it, it'll only take a minute and you'll know!.
Old Oct 20, 2017 | 09:59 AM
sc2dave's Avatar
sc2dave
wow, I never would have guessed it was right in that area!!! Thanks very much, Alan, you saved me A LOT of work!!
Old Oct 20, 2017 | 10:01 AM
ntfday's Avatar
ntfday
Veteran: Marine Corps
No, that will not work. The steering wheel lock is inside the column and it would require taking the steering wheel off to access.
Old Oct 20, 2017 | 10:14 AM
Alan 71's Avatar
Alan 71
Hi sc2,
ntf is right!
I just checked on my car and you can't move the lever unless the ignition is unlocked!!
I'm sorry to have miss-led you!
Regards,
Alan
Old Oct 20, 2017 | 10:18 AM
Don Rickles's Avatar
Don Rickles
2017 C3 of Year
Isn't this thread teaching those "Bad Guys" how to steal a car easily....
Old Oct 20, 2017 | 10:22 AM
sc2dave's Avatar
sc2dave
And, also teaching the Good Guys, that they should always have an alarm or any other theft prevention means, so that they don't get their car stolen.lol
Old Oct 20, 2017 | 10:28 AM
Don Rickles
2017 C3 of Year
Not really a laughing matter, in my opinion....but if you're ok, I'm ok.
Old Oct 20, 2017 | 10:58 AM
High Country 72's Avatar
High Country 72
Not sure about a 71, but some thieves used a slide hammer in the key slot to pull the lock cylinder. It's on held in by a small tab at rear of cylinder (see photo). Removing it this way may damage the cylinder and / or the column housing. You could also do a search on Chevy Ignition lock cylinder removal.
You can see the tab on the left end of the cylinder
Old Oct 20, 2017 | 11:33 AM
Don Rickles
2017 C3 of Year
Small screwdriver pop out the slot of diecast to reach the release spring under the steering wheel center cap......Cylinder should pop out.....OK?
Old Oct 20, 2017 | 11:46 AM
Peterbuilt's Avatar
Peterbuilt
Remove the slag from the far right rectangle, push down with a small screwdriver while pulling out the key switch.
Now use a screwdriver and unlock the column.
Watch from 2:25
Old Oct 20, 2017 | 01:14 PM
cv67's Avatar
cv67
St. Jude Donor '05
is this the 454 4spd $1000 beater you were posting about?
Old Oct 21, 2017 | 01:03 AM
sc2dave's Avatar
sc2dave
I just wanted to make everyone realize how easy they can get their ride stolen and encourage them to get some theft protection. I see too many cars without ANY theft deterrent,then the owners wonder how their car got stolen.
Old Oct 21, 2017 | 01:04 AM
sc2dave's Avatar
sc2dave
Yes, as of 10:00 pm today, it's finally in my backyard! Pics to follow tomorrow
Old Nov 9, 2017 | 10:42 PM
sc2dave's Avatar
sc2dave
Yes
To Removing ign switch on '71
