My RX8 seat project.
Old Nov 7, 2017 | 07:05 PM
76CRVT's Avatar
76CRVT
7th Gear
How well do the mounting holes line up with the original seats?
Old Nov 7, 2017 | 07:53 PM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
Seats look great!
Old Nov 8, 2017 | 08:36 AM
PainfullySlow's Avatar
PainfullySlow
Originally Posted by Team Evil
I REALLY like that little ball bag pad that you stitched into the seat bottom forward edge ! ! !
Looks comfy . . .
Well, they were there from the factory =)
Originally Posted by kanvasman
Great job. Sometimes the fabric will get creases in it from being folded up or something like that. A hair dryer gently applied will get rid of some of the lines in the seat. The sew foam makes it even more obvious. So will leaving it out in the sun for awhile. The heat will relax the fabric. The other issue that we have is where the seams go over a curve the fabric might go from over the foam to along side the foam. Not sure if I can explain that better, but in the process of pulling on the fabric it had a tendency to twist. The trick is to get it all the same way, on the side or on top of, not important, but it should go the same direction. Just some things that I have learned over the years. Not sure what you do for a living, but upholstery is a nice way to make a living. And ther's never a slow period. But the best part will be when someone asks who did your seats, you can say "I DID". Thanks for sharing this.
Those are some great tips, thank you. I was planning on using a heat gun to try to 'relax' the fabric a bit and I do get what you mean about the seams. Ideally I will fold each half back and it would get stitched down with the french seams but I didn't bother to do that with the upper piece as I knew it would not be a keeper.
I did a boat interior from scratch. my first attempt at upholstery work. decent, but not near as good as this. step-daughter sees the work and says "all right, you are officially gay!" why the un-manly stigma attached to sewing is beyond me. you gonna start doing seats for us?
I really do not understand the stigma but then again I am one of those people who tries not to let a 'macho' image get in the way of me doing something that I want to do. Back in my suit and tie days I recall wearing a pink shirt one day and a well built, obviously gym trained guy commented on it. My response was 'So you are a big, strong man...who is afraid of a color?' That pretty much ended the conversation.
Oh, and thanks for the confidence but I really only do this kind of stuff for myself. I enjoy the learning experience but I don't expect that I will be trying to make a business out of it.
I have no idea. I never expected to use the seat tracks off of these. I expect that I will have to fab up a few brackets to attach these seats to the original seat tracks so mounting should be perfect.
Thanks for the responses all...the work continues.
Old Nov 8, 2017 | 06:38 PM
ignatz's Avatar
ignatz
Impressive! I remember doing my stock seats and wondering if I was messing up. Then I attached the stays and wow everything popped. Do these seats get any stays?
Old Nov 8, 2017 | 08:25 PM
PainfullySlow
Not sure what you mean by stays?
Old Nov 8, 2017 | 11:20 PM
ignatz's Avatar
ignatz
It's a length of steel rod that slides into a long thin sleeve sewn on the back of the seat material. Hog rings grip the stay and pull it down so that the foam bulges and pushes the upholstery taut. I see four places where stays might have been used, the long curves on the seat bottom and back where you don't have stays and the bolsters where I thought maybe you did. I don't know what year your car is and whether you have the original seats and upholstery but the earlier seats like my 69 had them.
I can't really be sure what I'm seeing but aren't those hog ring pliers and I thought maybe I was seeing stays along the bolster seam.
Not meaning to be critical I was just curious and I repeat this is really fabulous work I would never have attempted.
Old Nov 9, 2017 | 07:24 AM
PainfullySlow
Ah, being new to upholstery work I had no idea what those were called. Yes, there are stays sewn into the seat and I did use hog rings to hold them into place.
Old Nov 10, 2017 | 05:29 PM
M Pete's Avatar
M Pete
Awesome. I'm interested on how these bolt in for you.
Old Nov 12, 2017 | 07:50 PM
The13Bats's Avatar
The13Bats
Rut row,
We have a resto modder who doesnt care about forum catch phrases and makes what he wants happen with what he wants it to happen with, super sweet seats,
I love that out of box thinking and looking forward to your build thread,
Old Nov 13, 2017 | 09:58 AM
PainfullySlow
Rut row,
Thanks Bats!
I guess I am too new here to know all the catch phrases :-p
