Mice and storage
It's getting consistently cold out now so I doubt I will be driving the vette much anymore.
That said, in the past I have put irish spring soap around the wheels of the corvette and never had an issue with mice. Last year, I forgot to do it and mice made a nice home out of my car cover bag on the back of my car (under the car cover). Luckily no paint damage was done.
This year I was proactive and when the temperatures started dropping in September I put the soap around the perimeter of my garage to try to deter any mice from coming in. However, this past Sunday, I got the car out and while it was idling (waiting on the wife to come out) I notice a field mouse under the car. It ran off but that leads me to believe they are already in the garage and may be in the car somewhere.
So I wanted to reach out and ask for suggestions to keep my car mouse free. I will leave the soap around the perimeter and put soap around the wheels too. Is there more I should do?
If I put some traps out, would that just entice more to come into the garage because of the food or would that get rid of the ones I have?
It is a single car garage, at an apartment, detached from the building, and is not climate controlled. I have plugged holes in the garage as much as I can, but there are still some openings where they could get it. So it really comes down to preventing them from getting in the car.
Thanks.
When I had mice in my house - they actually ATE & gnawed on Irish spring bars!!!
I guess the mice are tougher down here!!!
Richard
I've always used Bounce sheets with good success.
It's now my winter project.
Allan
Mice can fit through a pencil sized hole, so remember that. Like I said... the only way to completely get rid of them is to take out their entrances/exits and then trap. If you just bait/trap without sealing the holes, forget it. I had probably a hundred in my garage at my previous house which was a new house (mice don't discriminate), was a losing battle. I'd catch 4-6 a day, but that only thinned the heard for a while.
After we moved, I had them coming into my finished basement. It was war. I found that they were coming in through the hole behind the electrical box. Sealed that up and poof... problem done in a matter of days and haven't had issues in 3 years now (crossing fingers).
So my 2 cents, you might win small skirmishes with these suckers by just trapping or whatever... or you can be smart about it and win the war.
I make up a "wheel-of-death". 5gallon pail, popcan suspended across a section of wire over the pails open end. 4-5" of windshield washer fluid or water/anti freeze mixture (so it doesn't freeze) in the bottom for the mouse/critter to drown in. Put peanut butter on the can and around the edge of the pail a few inches down, lay wood, plywood or whatever on the edge of the pail down to the floor as a runway for the critters to get to the top of the pail. They'll reach for the PB and fall in and drown.
AF works better that WW fluid. When they die they wont stink. With WW fluid the critters will stink after awhile. If you have easy access to the pail over the winter and depending on the winter temps you could get away with water only.
If a cat or dog could gain access to the pail don't use AF, use WW fluid.
I put them under the seats, in the wiper cowl area by the end screens and stuff one in each tailpipe. Lay one on the floor on each floorboard as well. One in each storage compartment, glovebox (if so equipped) and a few scattered around the engine compartment. Make a list of where you put them and sit the list on the dash of the car so you remember to remove them all in the spring.
I open mine about 2". The smell of the dryersheets aren't to bad, at least the ones I use. Not "Bounce" but some no-name cheepies.
Ive tried cedar scented *****, seemed to be ok. Put down some cardboard on the cement floor, Ive seen MB's damage old concrete as they dissolve.
