73 Tachometer Help
Old Nov 12, 2017 | 07:40 PM
Heading120's Avatar
Heading120
Cruising
Default 73 Tachometer Help
Tach seems accurate at low rpm' s but only goes up to between 2000 and2500 rpm.
Where should I start?
Old Nov 13, 2017 | 07:47 AM
Revi's Avatar
Revi
Look at the distributor gear, then then cable, then tach itself.
You can disconnect the cable at the distributor and use a power drill to spin the cable and watch the tach. (Not sure what the RPM range is on a power drill?)
The tach cable can only be removed from the tach side, which means getting under the dash and unclipping the cable on the rear of the tach.
Old Nov 13, 2017 | 07:55 PM
Heading120's Avatar
Heading120
Cruising
Thank you. Heading120
To 73 Tachometer Help
