Pilot bearing
Old Jan 27, 2018 | 06:31 PM
68bigblock's Avatar
68bigblock
Default Pilot bearing troubles
I'm in the process of replacing the clutch, pressure plate, throw out bearing, and pilot bearing in my 68 big block coupe. The pilot bearing that came in my kit will not fit the crankshaft. The pilot bearing is a little too small. I went to four parts stores today, and they all have the same size bearing for my car. they are all too small. What are my options? I could score the inside slot where the pilot bearing slides in so it would hold it or have one custom made. Are there any other options? Has anybody else had this problem? Thanks in advance.
Old Jan 27, 2018 | 06:33 PM
68bigblock's Avatar
68bigblock
I forgot to mention my car is a 68 Coupe 427 390 horse
Old Jan 27, 2018 | 08:40 PM
loup68's Avatar
loup68
Army
Try Auto Gear. A lot of the pilot bearings have iron in the brass. They sell brass ones. Maybe NAPA has one. Talk a magnet with you. I am just repeating what I have read on this wonderful, informative forum. Lou.
Old Jan 27, 2018 | 09:21 PM
derekderek's Avatar
derekderek
1.094 is the standard OD for pilot bearings. your crank probably had one spin in there and made the hole in your crank a little big. maybe get some thin shim stock and wrap a layer of that around the bushing and see if it presses in.
Old Jan 27, 2018 | 09:26 PM
Ryan Menzies's Avatar
Ryan Menzies
OP try PB-656-HD bushing from National. I'm 95% certain that is what I used on my 496 and it was NOT metallic as per the trusty magnet.
https://www.summitracing.com/int/par.../applications/
Cheers,
Ryan
Old Jan 27, 2018 | 09:28 PM
derekderek's Avatar
derekderek
I don't know if there is enough length on the pilot shafts to use the bigger step in the crank. This is actually a mercruiser bushing for putting a Merctrans on a big block. Pilot is ford-sized at .667 instead of the chebby .59 or so. But they can be found with this 1.7-ish OD and Chevy ID. Also available with a roller bearing inside.
Old Jan 27, 2018 | 10:01 PM
TimAT's Avatar
TimAT
Use some caution here-- if the input shaft on the trans and the pilot bushing don't have any clearance, the input will force the crank forward in the block and destroy the thrust bearing.
Old Jan 28, 2018 | 05:15 AM
derekderek's Avatar
derekderek
yes, it will take some measuring to see if it will work ahead of time. knurling the bushing or the crank or both and green Loctite is apparently another option.
Old Jan 28, 2018 | 10:18 AM
68bigblock's Avatar
68bigblock
I sent Dorman an email requesting the part number for a pilot bearing slightly larger than the original (1.093). I'm thinking a 1.11 or 1.12 would work. My caliper arms are to short to reach into the housing to get an exact measurement.
Old Jan 28, 2018 | 10:27 AM
joewill's Avatar
joewill
several will tell you that this is bad advice.. but if all else fails.. just reuse the old one... it could be just fine...
Old Jan 28, 2018 | 12:00 PM
540 vette's Avatar
540 vette
Freezer overnight. Had the same problem. Also cleaned up the inside with a little emory cloth.
Old Jan 28, 2018 | 08:44 PM
68bigblock's Avatar
68bigblock
Where would you find thin shim stock?
Old Jan 28, 2018 | 09:27 PM
TimAT's Avatar
TimAT
Oddly enough, Hobby Lobby has thin sheets of brass.
Old Feb 12, 2018 | 02:22 PM
68bigblock's Avatar
68bigblock
Dorman does not have a bushing. I have called several manufactors, and nobody has the bushing. The engineer who built my engine says "do not use a shim!" So I guess my only option is have one machined.
Old Feb 12, 2018 | 04:19 PM
69ttop502's Avatar
69ttop502
Call Autogear!
Old Feb 12, 2018 | 06:47 PM
68bigblock's Avatar
68bigblock
Originally Posted by 69ttop502
Call Autogear!
I just sent them an email. I will follow up in the morning with a call
Old Feb 12, 2018 | 06:59 PM
DUB's Avatar
DUB
If I may...I would get a machinist to come by and use a snap gauge to make sure you get the inside diameter to what you know it is actually.
And hopefully when they make you one...they use the oillite bronze.
DUB
Old Feb 15, 2018 | 10:04 AM
Spot Rot's Avatar
Spot Rot
Default Oilite
Be very wary of aftermarket pilot shaft bushings, even the bronze ones. Most are just cheap copies made in China to look like the OEM part. Their dimensions can be off, and worse they are not oil impregnated like the original bearings.
Make sure you get an original Oilite bushing. If not you may harm your expensive to replace pilot shaft, have nasty noises when the clutch is in when in a gear, and replacing the bushing later is a real PIA.
This may be of help:
https://en.wikipedia.org/wiki/Oilite
If anyone knows where to buy an original Oilite bushing, that source would be of great help.
Old Feb 15, 2018 | 01:35 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Autogear makes an oversized one. See their chart in the link.
http://www.autogear.net/wp-content/u...hing_chart.pdf
To Pilot bearing
