Interior A-pillar windshield trim replacement?
Old Feb 12, 2018 | 03:23 PM
pmr2000's Avatar
pmr2000
Default Interior A-pillar windshield trim replacement?
Anyone have any diagrams or replacement tips for a 1975 coupe? Could not find any searching the forum.
I only see one upper screw, hoping dash pad does not need removal. Winshield header trim is o.k. shape, I do have cracks in door panels, interior is original.
My thinking was to just replace the a-pillar trim since it is missing vinyl at the top and foam is exposed, looks bad with t-tops off.
Also, any recommendations on where to buy replacements? Wilcox, Corvette America, etc.?
Thanks.
Old Feb 12, 2018 | 06:49 PM
DonnieP73's Avatar
DonnieP73
Your 75 should be the same as my 73. After you remove the screw, you should be able to remove the trim that is held in 2 places by plastic
velcro type holders. You can see them on this diagram that are numbered 4.
Donnie
Old Feb 12, 2018 | 07:14 PM
Peterbuilt's Avatar
Peterbuilt
You have to remove the sun visors and the top trim first then the "A" pillars will come off.
Thanks.
Old Feb 13, 2018 | 07:32 AM
Pa'svette's Avatar
Pa'svette
St. Jude Donor '16-'17-'18,'19
No need to remove the top trim, just the first two screws on that side. I just ordered one from corvette central. I'll let you know how it looks when it arrives.
Old Feb 13, 2018 | 08:05 AM
Alan 71's Avatar
Alan 71
Hi pmr,
As Donnie's pic from the AIM indicates the trim piece is held in place by 2 velcro type 'pads' too.
It often takes some pulling on the trim piece to get the velcro to release.
Regards,
Alan
Old Feb 13, 2018 | 09:15 AM
pmr2000's Avatar
pmr2000
Thanks and that is great news and a relief, did not want to disturb too much old plastic.
These new pieces will definitely improve the appearance with my T-tops off!
Old Feb 15, 2018 | 03:55 PM
Pa'svette's Avatar
Pa'svette
I just got mine. Color and fit is very good. Velcro was already installed.
Old Feb 15, 2018 | 06:24 PM
7T1vette's Avatar
7T1vette
The replacement pieces I got from Corvette Central [a few years ago] didn't fit worth a hoot. The plastic locking strips (aka Velcro) were not the same and did not mesh with the original pieces on the frame; the pieces were not shaped the same as the originals and had to be "massaged"; called C.C. and they couldn't care less....
I ended up removing the plastic locking strips from the original pieces and transferring them to the new pieces, reshaping the new ones to fit, and re-dyeing them to actually match my interior. PITA!!
Old Feb 16, 2018 | 04:03 PM
Pa'svette's Avatar
Pa'svette
I just noticed I was wrong, it was Corvette America not Corvette Central.
Old Mar 21, 2018 | 09:43 AM
pmr2000's Avatar
pmr2000
Just got mine via Wilcox from Al Knoch direct ship.
Color match is good, will try to get them on today hopefully good fit.
Old Apr 2, 2018 | 01:30 PM
pmr2000's Avatar
pmr2000
Finally swapped these in. Fit is good velcro a little off.
I did noticed the right t-top latch dents into the vinyl trim at the top. Probably why my right trim was so bad.
T-tops seem to fit well, left latch does not dent left trim.....has anyone ever seen this issue? Any t-top adjustment that may help?
P.S. what a pain to get the visors back on! Hard time aligning the screws back in holes.
To Interior A-pillar windshield trim replacement?
