c-3 pillar door hinges
Old Feb 19, 2018 | 12:21 PM
My1939's Avatar
My1939
1st Gear
Default c-3 pillar door hinges
took old hinges off - now need instructions how to install new hinges
Old Feb 19, 2018 | 12:25 PM
lvmyvt76's Avatar
lvmyvt76
opposite way of taking them off??? adjust door gaps, check door closing against door strike? drink beer? paint new hinges before installing, so they look good?
Old Feb 19, 2018 | 12:52 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
FWIW: start by using the same shim stacks you removed.
Old Feb 19, 2018 | 02:04 PM
Alan 71's Avatar
Alan 71
Hi My,
Hopefully the hinges left some 'tracks' in the paint which will help you get them back in place on the hinge pillar relatively close to where they originally were.
This will help you not have to start from the very beginning in locating the hinge positions.
Regards,
Alan
You might get hint from inside the hinge pillar too.
To c-3 pillar door hinges
