C3 Camaro zl1 rear suspension swap
Old 11-10-2020, 04:25 PM
  #61
bfit
bfit's Avatar
Richard the multi link used in the late model Camaro is fare more predictable . Than the stock system , I run a Ridetech coil over setup in my 70 model, I find it a superior setup compared to the stock suspension , but I believe the Camaro setup will work better when we get back to the track. Who knows when that will be with covid hold up the world.
as for engine etc . I’m using an lsa with tr6060 , third member
9” Gforce conversion
bfit
Old 11-10-2020, 05:26 PM
  #62
Richard Daugird
Richard Daugird's Avatar
I had to look it up, I didn't know what an LSA is. Pretty impressive.
Old 12-15-2020, 06:22 AM
  #63
bfit
bfit's Avatar
Here
Joint preparation
Replacement tacked in
splice RH Side rail
fit
Old 12-15-2020, 06:39 PM
  #64
69427
69427's Avatar
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Originally Posted by bfit
I made a little progress this weekend
I've missed some of the updates lately. Whatcha got going on in this picture?
Old 12-16-2020, 05:07 AM
  #65
bfit
bfit's Avatar
That photo is the RH front chassis rail., I fitted a 1 3/4” x 1/8” tube through the rail .
You can see the top control arm mounting position in the top of the photo
photo this post show a little more progress
Old 12-16-2020, 05:15 AM
  #66
bfit
bfit's Avatar
Old 12-16-2020, 02:56 PM
  #67
69427
69427's Avatar
Respectfully, I was hoping for a bit more (engineering/design) detail there.
I did the same/similar thing to mine a bunch of years ago while I was putting the C4 suspension on my spare frame.
Old 12-16-2020, 09:56 PM
  #68
bfit
bfit's Avatar
I don't go into to much detail as there are far to many variables, and I don't think a long in-depth thesis would be suitable on the forum ,
Bfit
Pegan2261 (11-19-2021)
Old 04-01-2021, 04:15 PM
  #69
bfit
bfit's Avatar
It’s been a while, I’ve been working on a replacement front crossmember, with the view of lowing the radiator in the frame, to accommodate the OTR intake.
Bfit
CraigH (04-02-2021)
Old 04-01-2021, 08:33 PM
  #70
M A Fry
M A Fry's Avatar
Hi bfit, just been refreshing my memory by going back through your photos and one thing struck me, I think you will have to fit light truck tyres to your vette to be able to cope with all the extra weight of the steel in your new chassis.
Old 04-01-2021, 09:59 PM
  #71
bfit
bfit's Avatar
No I don’t think so.
The extras in the chassis calculates to 76 lb
The 69 currently has a 454 on board replacing that with an LSA Saves 150lb
I think total weight will be close to original
I don’t know the weight of the multi link I’ll get to that in due course,
I hope to post a few photos of the radiator support I’m building in the next few weeks , it’s 2mm material and will weigh less than the OEM part
Bfit
Old 09-18-2021, 02:59 PM
  #72
bfit
bfit's Avatar
It been quit some time between posts here, I have found time to get back to this project.
Old 11-18-2021, 06:07 PM
  #73
jokeitch
jokeitch's Avatar
keeping an eye on this.
if your solution works out, i might copy it for my ev project since the zl1 rear is pretty nice
problem will be shoving a tesla rear drive unit into the cradle without compromising it
Old 11-26-2021, 05:29 AM
  #74
bfit
bfit's Avatar
Tesla drive ,and a c3 chassis , I’m thinking the trailing arm system out of a holden commodore VT-VZ the same unit is used in the GTO in the US , would lend its self to the Tesla drive .
bfit
Old 11-26-2021, 12:51 PM
  #75
7T1vette
7T1vette's Avatar
Received 2,718 Likes on 2,275 Posts
You do amazing work. But I have to ask....Wouldn't it have been a lot easier to just build your own frame to mate with the suspension systems you selected?
Old 11-26-2021, 04:00 PM
  #76
bfit
bfit's Avatar
The answer to your question is Yes. It would be far better to build the frame ,
. I did some work in that direction with the intension of using a c6 rear suspension , Building the chassis using 3mm vertical members and 4mm top and bottom members of the box section .
if I last long enough I’ll built a frame from scratch, I’m looking for an LT5 n transmission for that project.
Bfit
Old 11-05-2022, 04:04 PM
  #77
bfit
bfit's Avatar
Default It’s been a while
I haven’t spent any time on this for some time, this weekend I found time to fold the right hand top shock mount and weld into the frame
bfit
Quick Reply: C3 Camaro zl1 rear suspension swap
