Cowl Shake?
I have had all tires spun balanced. I had the drive shaft balanced. The front suspension and steering is good (according to my mechanic).
Is this the cowl shake that I read about? Can it be remedied?
Could it be something else that I am not identifying?
HELP!
I believe 'cowl shake' was seen on early 68 cars and manifested itself as a shake of the steering column and a creaking noise in the cowl area when traveling over very uneven terrain such as railroad tracks and pot holes.
If you're seeing a vibration of the fenders I'd wonder about the bond of the fenders to the clip, the attachment of the core support to the fender aprons and front crossmember, and the 'bracing rod' from the center/bottom of the core support to the brace that runs across the front of the clip (behind the bumper).
Do 68 cars have it?
Have you checked for that rod?
Regards,
Alan
The rod.
Perhaps you could add the support rod to your 68 to help control the front fender oscillation?
Is there any reason to think the clip isn't bonded to the cowl properly or that the core-support isn't bolted to the aprons and forward crossmember properly?
Regards,
Alan
Just happen to think...IS the bottom of the core support bolted to the crossmember on all 68 cars? I seem to remember a thread about differences in the early crossmember/core-support?
When I said that I could see the fenders vibrating, I was trying to communicate the severity of the vibration. The entire car shakes but the shake seems to be originating from the front of the car. (However, I cannot swear to the origin of the shake.)
The car is shaking in a very very rapid left-right rocking oscillation, like you would expect from an out of balance front tire. Looking at the tops of the fenders during the vibration, it appears that the up/down movement of the edge of both fenders is 1/8 inch or so. Slight visually, but moderate in the actual feel of the shake. After balancing and rotating the tires, the shake is unchanged. The steering wheel does not vibrate or shake at all.
Thanks for your thoughts on all of this. It is extremely frustrating, like chasing your tail.
Alex
Do 68 cars have it?
Regards,
Alan
The rod.
A vibration that begins and stops at certain speeds 'often' indicates a wheel or tire problem, or a driveshaft/half-shaft problem since it's those rotating parts that affected by the car's speed.
What about an out of balance rotor... or a hub/rotor that's not seated properly?
It sounds like you've checked most of those things. So?
Regards,
Alan
Can you duplicate the vibration at lower speeds when in lower gears?
Or is it purely speed driven?
Drive shaft was removed and balanced. I don't know what a half-shaft is.
An out of balance rotor did not occur to me. Can a solid metal rotor become so out of balance as to cause the whole car to shake, even if the breaks do not oscillate as would happen wit a warped rotor?
I would imagine that the rotors and hubs are seated properly as the vibration was present before and after tire rotation. Surely any seating issues that were present would have been corrected with the tire rotation at Discount Tire.
The issue is entirely speed driven and only occurs in a very narrow speed range of 52 - 58 mph. Very strange issue ...
As always, thanks for your help!
Alex
Regards,
Alan
On a straight "smooth" highway get the car up to 75 mph provided the speed limit allows. Carefully place the shifter into NEUTRAL while releasing the throttle down to idle. Keep an eye on the speedometer to notice when the vibration starts and stops. This procedure may make it easier to decide which area of the car is causing the vibration...one example: No vibration could mean a damaged motor mount or transmission mount that causes vibration only under a constant even load....rare, but it happens
Let us know what happens.....or what doesn't happen.
