I'm hoping to "upgrade" my interior a bit with a wood rimmed steering wheel, matching shift ****, wood kit for the center dash and console(s) and the addition of the wood door inserts. Several of the usual suspects offer the trim panels alone or as a part of the new door panel package, all say that they're as original to what was available from GM. I've never seen a C3 with these door inserts myself and was wondering if the "teak" was real wood, plastic composite, thick vinyl "contact paper" or worse?
I love what I've seen in the on-line adverts and catalogs, just wondering what I'm getting into. Any help here would be appreciated.
Thanks—
TC
Where did you find the matching shift ****?, love that idea
I searched out the shift **** on Ebay a long while ago, a nice piece with the deep insert to allow for the shifter to rise upwards and inside of the **** as it does with the stock chromed ball. The Corvette crest is a nice cream and gold cloisonee with the crossed flags and perfectly matches the horn crest that came with the Moto Lita horn base and mount. Hopefully, with the console wood and the door panel inserts it'll all look of a piece, just need to find out if the inserts are genuine wood or if I'll have to fashion my own. Thanks—
The "replacement" inserts I received were basically melamine (like counter-top or the stuff they glue onto particle board shelves etc. About 1/32~1/16" thick and didn't fit the original chrome inserts worth a damn.
Maybe if you bought the chrome piece with the wood grain already installed they'd match properly.
When I bought my 77 it had a wood shift ****. I have the black inserts on my doors so figured someone must have added it, was that a factory option? I remembered my 73 had a black **** so figured that was what was supposed to be there so that’s what I bought
Thanks VERY much guys, looks like a home made option is the way to go for sure ! I have some nice burl wood veneer and a selection of other interesting woods left over from my Father's estate. I'm not much with saws and such, but I can do it if I'm careful enough I suspect. I saw a "kit" for re-doing al of the dash center, console tops, and such with burl wood that looked nice, but was expensive, could be worth it as the stock "wood grain" console top insert looks like trash, although it would make a terrific pattern for a burl wood veneer insert, wouldn't it? "Easy Mike," when I wrote that I'd never seen a C3 with these inserts, I added "myself." Meaning that I've never seen them in real life, only in pictures like the one that you posted. This was the whole meaning for my posting, as I'd never come across them/saw them in person I wanted to know what was really going on with them. Photographs can makes things look anyway that the advertiser wants them to look, as "Moser's" wonderful thread demonstrated SO very well.
Anyway, thank you all once again, you've been a terrific help as always ! !
Oh, as a follow up to the whole wooded shift **** mention, I found this on Ebay yesterday. Similar to the one that I picked up so long ago, has the deep well for the shifter to recede into when selecting reverse and all but in pretty shabby condition, especially the cloisonee emblem. Smaller and a bit different from the one that I have, but at least representative of what's out there. There are others, but the recess for the shifter isn't always present.
and found out that the spring under the button is what causes the shifter to stop at the various gears, the main spring inside the shifter shaft at the other end only makes it so you need to press the button to take it out of park. Without the button spring you could pull the shifter from reverse all the way to low or back without touching the button.
M
