First Oil pan removal/installation
Old Mar 23, 2018 | 11:39 AM
Sweet Sade's Avatar
Sweet Sade
5th Gear
Default First Oil pan removal/installation
Tired of oil seepage and a dented oil pan so I'm getting ready to change my oil pan out and wanted so good advice. There is a tie rod or some type of suspension under the pan , will that cause a problem? or should it slide out at an angle?
Sweet Sade
Old Mar 23, 2018 | 12:02 PM
robmccon's Avatar
robmccon
You should be able to gain the room by removing and dropping the idler arm. Here's a related thread with some more info - https://www.corvetteforum.com/forums...n-removal.html
Old Mar 23, 2018 | 12:08 PM
MelWff's Avatar
MelWff
also switch to the one piece oil pan gasket from Felpro
Old Mar 23, 2018 | 12:22 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Just to be sure.......lay the new oil pan upside down on a flat surface /granite counter top and check for warpage at the gasket area.
Use acetone or brake cleaner to degrease the area on the engine block to avoid leaks
apply a dab of oil-resistant silicone gasket sealer in all sharp corners of the engine block where the gasket fits.
Tighten the oil pan bolts equally in increments to avoid crushing the gasket creating leaks.
(don't ask how I learned about leaking NEW gaskets )
Old Mar 23, 2018 | 12:28 PM
Sweet Sade's Avatar
Sweet Sade
5th Gear
Thanks, That was the second thing I bought.
Old Mar 23, 2018 | 12:32 PM
Sweet Sade's Avatar
Sweet Sade
5th Gear
Thanks Doorgunner, great info!
Old Mar 23, 2018 | 12:35 PM
Sweet Sade's Avatar
Sweet Sade
5th Gear
I saw the threat and I will tackle this soon. Appreciate the help.
Old Mar 23, 2018 | 12:36 PM
69_Shark's Avatar
69_Shark
Drain the oil first though . . . . . .
heh heh!
Scott
Old Mar 23, 2018 | 12:53 PM
doorgunner's Avatar
doorgunner
heh heh!
Scott
NOT if you mix equal parts combat-related PTSD with enthusiasm!
heh heh..................................... .........
To First Oil pan removal/installation
