Ignition shielding
Old Mar 24, 2018 | 02:25 PM
danh77's Avatar
danh77
Default Ignition shielding
When I bought my 77 all of the shielding had been removed, I have been acquiring pieces over time and since it wasn’t snowing today I went to the garage to see what I have. I think I have the wrong dist cover. What I have seems to small to cover the cap and wires, hopefully one of you guys may know what I have. It has 4 sort of rubber nubs on the top cover which seems to hold some type of inset to the underside of the cover. I figured I would ask here before digging out my aim although I don’t see any part numbers on it. I’ll try to get a pic up shortly
Old Mar 24, 2018 | 03:00 PM
Alan 71's Avatar
Alan 71
Hi d,
It sounds like you MIGHT be describing the 'one-piece' distributor shield that was used beginning near the end of the 70 model year, (12800), and continued through the 71 & 72 model years.
Regards,
Alan
Old Mar 24, 2018 | 03:22 PM
69FASTFUN's Avatar
69FASTFUN
The 77 cover is larger than the 71 to 74 to cover the larger HEI distributor.
Old Mar 24, 2018 | 03:26 PM
danh77's Avatar
danh77
That’s it Alan, awesome picture as usual, well time to find the correct piece, or maybe get a 71 or 2.
Old Mar 24, 2018 | 03:29 PM
gbvette62's Avatar
gbvette62
The 75-77 top shield is larger, to cover the larger HEI distributor cap, and doesn't use the plastic insulation, or the plastic rivets to retain it.
The 75-77 top shield also uses different top supports, than the earlier top shields.
Old Mar 24, 2018 | 03:47 PM
KenSny's Avatar
KenSny
Well, the OP has not said he has the stock HEI distributor, if so then getting anything but a '75-77 will not work. Don't see why he wants a 71-72 now as he posted later unless he has swapped out the distributor for a non-hei. Unless of course he keeps the shielding he has and swaps out the car. Maybe that's what he means.
Old Mar 24, 2018 | 03:54 PM
danh77's Avatar
danh77
It was said in jest, figuring since I already have the part why not get another car.
Old Mar 24, 2018 | 04:03 PM
KenSny's Avatar
KenSny
If my wife was making that decision she would say "keep the shielding and get rid of the car so I can have more room for my gardening stuff (i.e. crap)". Somehow she thinks the garage is hers - what gall.
Old Mar 24, 2018 | 06:18 PM
oldgto's Avatar
oldgto
Ummm.... NO. The garage is for CARS, and cars or car stuff alone. NO bicycles, lawn mowers, shovels, rakes, or other "implements of destruction", or non-car crap. Ken, you need to get this under control quickly!
Old Mar 25, 2018 | 07:41 AM
Blue73Shark's Avatar
Blue73Shark
Check this thread in the C3 Parts List:
https://www.corvetteforum.com/forums...shielding.html
Good luck on the hunt.
Fran
To Ignition shielding
