Rear leaf spring straps correct??
Old Mar 31, 2018 | 08:41 PM
revitup's Avatar
revitup
Originally Posted by KapsSA
The actual difference in the carriers is the size of the bolts.
Early carriers meant for use with 2 1/4" springs used 9/16" bolts.
Later with the 2 1/2" springs used 7/16" bolts so the spacers were needed with the 2 1/4" gymkhana springs.
Interesting, thanks, I never knew that. I thought the hole pattern was different. Maybe one could drill and tap the 7/16" holes to take the bigger bolts to fit the 2 1/4" spring without using spacers.
Old Mar 31, 2018 | 10:11 PM
general ike's Avatar
general ike
2017 C3 of the Year Finalist
St. Jude Donor '20- '21
Or rebated bolts although I am not sure who would make them. Ike
