Engine Date Code
Everything on this car is correct regarding date codes and casting numbers and or part numbers - tranny, rear, heads, intake, carbs, etc. The issue is the date code on the block.
The casting number on the block is correct for a 69 427/435HP. I have the protect plate and the engine number has the correct SUFFIX "LR" - so it should be a real car, I don't have a build sheet, but I am not sure that the block is correct based upon the date code.
This date code is on the passanger side below the freeze plug, which I read is where they sometime appear in 69. It looks like January 15, 1969 - well the production date for my car is December 69 (that is a fact based on the VIN and Trim tag).
Is it possible that the block was almost one year old and used in this car? Also, you can also look at this date code and it could be a 0? See picture.
This is the block casting number and potential applications:39635121969-71427335, 390, 400, 425 COPO, 430, 435,454345, 360, 365, 390, 425, 450 2&4 bolt
I have read on other sites that this block was used in late 69 vehicles. They had an extended production year in 69 going into December.
Looking for feedback?
Bob Messina
"Is it possible that the block was almost one year old and used in this car?"
Isn't it generally accepted that the casting date (and the engine assembly date) must precede the vehicle assembly date by no more than 6 months?
Perhaps someone with 69 427 knowledge will know if there were some exceptions to this thinking during 69 production for very late cars like yours (December 69 assembly).
What is the cars sequence number?
Regards,
Alan
Bob Messina
Many folks believe it's a poor idea to use ANYTHING abrasive or something like a wire brush to aid in removing the paint from stamp pads and dates/numbers cast into the block itself.
At this point you don't want to take ANY chance of DEGRADING the stamped/cast information or the surface of the pad or block any further.
Use only liquid or paste paint removers.
Regards,
Alan
Looking at the top photo, I don't see anyway that's not an 8 in that date code. And an A which I assume is January. As far as, is it "possible" for the block casting date to be older than the manufacturing (assembly) date by a year? I have no idea what the numbers gurus in the hobby use for their official guidelines on whether or not that is an "acceptable" difference. I would tell you as someone who worked for 50 years in QA in manufacturing involving castings, forgings, machining, rework cycles, inventory transfers, etc. it would certainly be "possible" but probably not very likely in the case of automotive practices. I am aware of one auto assembly plant that typically had an engine inventory that was measured in hours, not days. So they tended to work pretty close to Just In Time manufacturing even in the old days. However, the random component could get sidelined and fall out of the cycle for a variety of reasons so pretty much anything is a possibility.
Regards,
Alan
I agree that one should NOT wire brush any # that is stamped in a part but the date tag is cast in & is part of the casting. yes paint thinner would be better but wire brushing the #'S shouldn't hurt.
PS I have looked at a few 67 BB 351'S that had #'S changed. Wire brushing them makes it show up like a sore thumb.
The broad answer to the original question is that the block cast date is too far out for normative practice.
Wider date spread between engine assembly and vehicle assembly on low volume, high HP engine options is known BUT all the individual engine component casting dates should be closer together. If all the other engine components make sense on the date codes being closer to car assembly date but just the block date is way off....
How could that happen? A complete engine assembly can sit in the que but a empty block that was in common usage in other applications has no place to just "hang out" for a whole year. The engine suffix stamp / VIN derivative is gone. The deck has been cut so the block will never be matching numbers. Vehicle value estimate would be for a non-original engine block Vette based on what is left. Nice to have the documentation for sure.
Second I am not expert but there were strikes at GM but I don't believe it fits your time frame. The sad answer is that it may not be the original engine to the car despite what the original owner says. How does he back up his statement? Build sheet?
Ike
