how to install
Old Apr 4, 2018 | 10:48 AM
Rick74's Avatar
Rick74
Navigator
Default how to install
how to install underbody tunnel insulation
Old Apr 4, 2018 | 12:02 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
From underneath. The insulation installs over clips in the underbody.
Old Apr 4, 2018 | 12:08 PM
Wee's Avatar
Wee
If your talking about the piece that goes over the transmission and not the color piece, it has to be cut in a couple of sections or the transmission has to be dropped.
Brian
Old Apr 4, 2018 | 03:57 PM
Alan 71's Avatar
Alan 71
Hi Rick,
Welcome!
I'm glad you're here!
As Brian explained, the blanket really needs to be cut into several pieces to get it in place with the body on the frame.
If you decide to cut it remember that part of the cut has to be in the area of the opening in the insulation for the shifter lever.... if it's 4-speed car.
Good Luck!
Regards,
Alan
Old Apr 4, 2018 | 04:21 PM
SB64's Avatar
SB64
Default Vette
Old Apr 5, 2018 | 10:30 AM
Rick74's Avatar
Rick74
Navigator
Thanks for your help! Great pics
Old Apr 5, 2018 | 10:35 AM
Rick74's Avatar
Rick74
Navigator
Originally Posted by Alan 71
Hi Rick,
Welcome!
Good Luck!
Regards,
Alan
Can this be done with trans and oil pan in place?
Old Apr 5, 2018 | 10:36 AM
Rick74's Avatar
Rick74
Navigator
Can this be done with Tran and oil pan its a 74 auto matic
Old Apr 5, 2018 | 11:02 AM
Mooser's Avatar
Mooser
yes but not very well or easily I don't think
I did mine with the trans in place but the driver shaft, exhaust and trans crossmember were all out as well as the shifter cables etc so it was relatively easy....
The insulation and the front horse-collar foam piece does make a difference in the heat coming into the interior, worth doing.
M
Old Feb 16, 2022 | 07:51 AM
Corbis's Avatar
Corbis
Installing the insulation blankets on my '69. I see these great pics and read about cutting, does anyone have pictures of the cut patterns? I can find any diagrams that depict the orientation of the blankets. And the precut rectangular holes seem to line up with the metal mounting tab for the splash shield and heat shield, but then it doesn't cover the peak of the trans tunnel.
Can anyone provide any pics? Thanks
Bill
Old Feb 16, 2022 | 01:52 PM
Mooser's Avatar
Mooser
Have a look here and see if it helps at all
https://www.corvetteforum.com/forums...nsulation.html
M
To how to install
