door panels
Old Apr 7, 2018 | 03:16 PM
sparky77's Avatar
sparky77
Default door panels
I'm about to order new door panels for my 77 L82 which one fits and looks best.
Thanks,Pete
Old Apr 7, 2018 | 08:27 PM
Duke94's Avatar
Duke94
Thanks,Pete
I think they're all made by Corvette America no matter who you buy them from. I had them on my 71' and fit fine and looked good.
Old Apr 10, 2018 | 08:31 PM
kansas123's Avatar
kansas123
Are Al Knoch's also made by Corvette America?
Old Apr 10, 2018 | 10:15 PM
sparky77's Avatar
sparky77
So hows the fit,I've heard that they don't fit to good.
Old Apr 11, 2018 | 09:32 AM
Street Rat's Avatar
Street Rat
Special ordered a set from Corvette America for my '81. They fit terrible.
Vertical gap in the front of the door panel. Will not bend over the top of the door well.
I'll probably end up using a heat gun to TRY to correct them.
Corvette America and Al Knoch are all that I found who made them.
Craig
Old Apr 11, 2018 | 09:44 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by kansas123
...Are Al Knoch's also made by Corvette America?...
No. From Al Knoch: "Everything we manufacture is made in-house from scratch..."
http://www.alknochinteriors.com/
Old Apr 11, 2018 | 10:05 AM
69FASTFUN's Avatar
69FASTFUN
Default Al Knoch Interior
I have always had good luck with the Al knoch interiors
Old Apr 11, 2018 | 10:58 AM
BBCorv70's Avatar
BBCorv70
I had trouble with door panels from Al Knoch.
The top contour was off causing the panel to rest a bit high on the door. The top center of the panel rested above the top of the door causing the hole for the lock shaft to be above the shaft.
When I compared the originals to the Al Knoch panels I noted the steel insert at the top of the panel was a bit off, the dip in the contour was shallow. I had to bend the steel a bit to get the panel to sit on the door properly. This was for both doors, not caused by an accident. The originals fit okay.
To be fair to Al Knoch, these panels were bought long ago at Carlisle. I didn't try to install them until many years later. Also had problems with poor quality trim on one panel and wrong positioning of the seat release button on the new leather seat upholstery. I wrote it off as a period where they had quality issues. Many who have bought from them more recently don't seem to have these issues. Just reporting my experience FWIW.
Old Apr 11, 2018 | 11:35 AM
stingr69's Avatar
stingr69
...and the ones we do not manufacture, we buy from others.
Old Apr 11, 2018 | 11:58 AM
revitup's Avatar
revitup
Got panels for my '77 from CA. Did not install them myself so I can't speak to how difficult they may have been to install. (Local hot rod shop installed them no charge as they were doing my carpet.) There were no complaints that I heard about fit and most important, they came out looking perfect. I chose not to order from Al Knoch because I had heard that their quality had declined as of late. Don't have first hand knowledge whether that's true or not.
Old Apr 11, 2018 | 02:51 PM
7T1vette's Avatar
7T1vette
The foam core on the repro door panels can warp to a 'new position' if they are stored for long in a fixed position. Several who bought them suggest that they be placed backside-up in the sun to soften a bit before installing. But don't let them get too hot....
Old Apr 12, 2018 | 04:21 PM
mrmagrath's Avatar
mrmagrath
My new ones were too curved. Took them off and bent them with a heat gun from behind. They sit a lot better now. Don't know what brand they are, as they came with the car.
To door panels
