Fuel line replacement
Old Apr 13, 2018 | 06:38 AM
Dan Fandrich's Avatar
Dan Fandrich
Default Fuel line replacement
I am in the process of a frame up reconstruction and I need to put new fuel lines on the frame. What exactly do I need to buy and how many.
Old Apr 13, 2018 | 06:39 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Model year? Some years have a return line, other years do not.
Old Apr 13, 2018 | 06:41 AM
Duke94's Avatar
Duke94
easiest way is to buy the pre-made tubes.
https://www.inlinetube.com/1968-1998-corvette-lines
Old Apr 13, 2018 | 06:59 AM
Dan Fandrich
Default Thank you for the reply
its a 1977
Old Apr 13, 2018 | 07:02 AM
Dan Fandrich
right but what are they called and how many do I buy. They don’t come in a kit like the break lines do. I’m new to this and confused by this one. Everything else has been pretty straight forward.
Old Apr 13, 2018 | 07:11 AM
Dan Fandrich
Default New at this
It’s a 1977, I need to know what they are called, and how many to buy. As it stands right now I have file lines running down both sides of the frame. But that’s about the extent of my knowledge on this subject.
Old Apr 13, 2018 | 07:16 AM
Mooser's Avatar
Mooser
The line(s) on the passenger side are the fuel supply, and if there is a second one it is the return line.
You should be able to see the lines attach at the fuel pump to verify if you have two lines
The drivers side line is the vapor line that runs up to the charcoal canister
HIH
M
Old Apr 13, 2018 | 07:18 AM
Easy Mike's Avatar
Easy Mike
...I have file lines running down both sides of the frame...
FWIW: fuel and tranny cooler lines for AT are on the passenger's side of the frame. Brake and fuel vapor lines are on the driver's side.
You may want to purchase the assembly instruction manual and service manual for your car. Both could help you with the project.
Old Apr 13, 2018 | 07:23 AM
Dan Fandrich
Default Thank you
This was a forced frame up build. I was looking for a project car I could learn on when I bought this one. The previous owner neglected to tell me that it had been in an accident and the frame was bent so I had to buy a new frame... I am definitely learning now.
To Fuel line replacement
