SB starter help
Old Apr 15, 2018 | 12:43 PM
corvetteload's Avatar
corvetteload
Default SB starter help
Need a recommendation for a hi torque starter for a 350 able to clear headers under 200$ . Any suggestions appreciated. Thanks
Old Apr 15, 2018 | 12:56 PM
60 SHARK's Avatar
60 SHARK
Ok, not quite sure why a stock starter won't do the job for your application? ?? ?
Old Apr 15, 2018 | 01:22 PM
corvetteload
I don' know why either. Seemed stock type starters were straining and actually cracked the last one. Had the one from Chevy on it but just found the one bolt that holds the armature housing on the floor . Apparently broke off in housing. That one lasted 5 yrs, was the go torque one but don' t feel like spending 200 right now so was looking for some suggestions. Motor is a blown sb
Old Apr 15, 2018 | 01:32 PM
60 SHARK's Avatar
60 SHARK
Their are cheaper remanufactured ones also,,
Ihave found them for less than $30.00
Old Apr 15, 2018 | 02:12 PM
drwet's Avatar
drwet
Assuming you have a Corvette with a 168 tooth flywheel, ask for a gear reduction starter for a 1996 Chev full size truck with a 350.
Old Apr 15, 2018 | 06:46 PM
DUB's Avatar
DUB
Just in case you did not know this.
If your factory starter does not have the support brace that attaches to the end of the armature housing...then YES... the starter can crack due to not being correctly supported....thus able to flex and move under a load
Your factory starter is not held in by ONLY the two bolts that hold it to the engine block...there is another part required.
DUB
Old Apr 15, 2018 | 07:43 PM
corvetteload
Dub, very aware of the brace, sb and BB. The starter I have is a Chevy hitorgue one, no provision for a support. Also not as large or heavy like the factory.
gm
12361146
Old Apr 16, 2018 | 05:26 AM
terrys6t8roadster's Avatar
terrys6t8roadster
My 69 which is basically stock has the OEM type starter, the 6t8 has a modified engine with headers got a MSD starter. I hear 'Powermaster' has good gear reduction starters. T
Old Apr 16, 2018 | 02:39 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I have an east coast electric and its rebuildable. They sell the replacement parts
http://ecae.com/starter.html
summit sells them too.
EDIT
And you'll need the diode kit as well
Old Apr 16, 2018 | 09:39 PM
C3 Stroker's Avatar
C3 Stroker
The Powermaster XS Torque has worked well for me. Light (only 8 lbs.), very powerful, fits with room to spare with headers, and reliable (well over 10 years so far, no heat soaking issues).........but not cheap. This one....https://www.summitracing.com/parts/p...6/applications
Old Apr 16, 2018 | 09:45 PM
JoeMinnesota's Avatar
JoeMinnesota
I am running a Powermaster Mastertorque 9612 on my 355 with Doug's headers. It required the diode kit for Install on my 1970. Works excellent (4 spd and 168 tooth flywheel) good clearance, miniature body and excellent cranking torque. I have only had it on for a year and roughly 1k miles. 210 at Summit.
To SB starter help
