71 bb shroud question
Old Apr 16, 2018 | 07:49 AM
autoalain's Avatar
autoalain
Default 71 bb shroud question
folks, 1st question, is small block and big block shroud the same? 2nd, I have seen metal and plastic on ebay for same year, can I assume it should be metal only? (71 454)
Old Apr 16, 2018 | 08:03 AM
Alan 71's Avatar
Alan 71
Hi a,
During 71 production 454 equipped cars had a plastic shroud while a simple round steel fan shroud was used on 350 cu.in. cars which have an aluminum radiator.
Regards,
Alan
A later car with a 454 engine and a plastic shroud.
A 71 with a steel shroud and aluminum radiator.
Old Apr 16, 2018 | 10:58 AM
Primoz's Avatar
Primoz
2017 C3 of Year Finalist
Nice pictures as always! Follow up question: did the manual and auto cars have the same fan shroud?
Old Apr 16, 2018 | 11:47 AM
Alan 71's Avatar
Alan 71
Hi PK,
I believe that for 70-72 production:
Only base motor, 4-speed cars had the steel shroud.
Base motor automatic, or base motor a/c, or base motor automatic and a/c cars, had a copper radiator and the plastic shroud.
All 454 cars regardless of transmission or a/c used a copper radiator and plastic shroud.
Regards,
Alan
Old Apr 16, 2018 | 12:04 PM
71 Green 454's Avatar
71 Green 454
Originally Posted by Alan 71
Hi PK,
Base motor automatic, or base motor a/c, base motor automatic and a/c cars, had a copper radiator and the plastic shroud.
Regards,
Alan
Hi Alan,
Just wanted to mention that 454's with a/c uses the 7 blade pointy finger fan blade along with the plastic shroud. Non a/c uses the 5 blade fan blade.
Dave
Old Apr 16, 2018 | 12:15 PM
Alan 71's Avatar
Alan 71
Hi Dave,
Thanks for the info!
Details about a/c cars that I'm just not as familiar with as I'd like to be or ought to be!!!!!
Regards,
Alan
To 71 bb shroud question
