Driver side headlight assembly
Old Apr 17, 2018 | 07:38 PM
nivensid's Avatar
nivensid
Default Driver side headlight assembly
1981 Corvette, under hard acceleration the driver headlight opens real fast and let off the gas it closes just as fast. Both headlights open and close with the headlight switch as they should. Any one else experienced this?
Old Apr 17, 2018 | 07:42 PM
KenSny's Avatar
KenSny
Vacuum problem.
Check vacuum lines running from the headlight back to carb.
Old Apr 18, 2018 | 01:23 AM
Antz81's Avatar
Antz81
Originally Posted by KenSny
Vacuum problem.
if not in the main lines to the headlight then in the control lines. May as well test everything while he's at it.
Old Apr 18, 2018 | 06:57 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Check the vacuum relay for the left side light.
Old Apr 18, 2018 | 07:15 AM
nivensid's Avatar
nivensid
Thanks everyone, have some investigating to do this weekend.
To Driver side headlight assembly
