I own a 1974 Corvette with the 350. I purchased what are supposed to be ralley rims off a 1969 Corvette. CorvetteAmerican.com list the tire size as 225x70 R15. Can I put a bigger size tire on this rim to make it look meaner?? and what size should I get?????? Thanks
Not sure what you mean by "meaner". But, if you want to use the stock 15" wheel rims, 235R60-15's are about the same diameter as the 225R70's. The later C3 cars came with 60 series radials on them.
235 width tires will fit on ALL pre-75 C3's. You may be able to fit 245's or 255's in the front (they will easily fit in the rear), but the wider tires may rub at 'full-steer'.
Hi BM,
You may find that the 235-60-15 tire doesn't give the look you describe because it's only 26.10 inches tall.
The 225-70-15 tire is 27.4 inches tall.
The 26.10 inch tall tire will look small in the wheel arch. It will be 'fat' but 'short'.
So when considering tires, go to a site that list tires by size and gives the height and width for each size tire.
That's the best way to compare them.
Regards,
Alan
I agree with Alan....wider tires usually result in smaller diameter, and the wheel well gap gets "huge". To me, the stock taller skinnier tires look the best on these cars.
