whose fuel line to get?
Old Apr 26, 2018 | 11:04 PM
3X2's Avatar
3X2
Default whose fuel line to get?
I need to replace the fuel line from the pump to the card. Any preference to brand? Classictube.com? inlinetube.com? Or ???. I looked at Paragons, Ecklers, Zip, corvette Central, etc and I'm assuming they get theirs from one of these two.
Old Apr 27, 2018 | 07:11 AM
Shovels and Vettes's Avatar
Shovels and Vettes
I recommend Inline Tube. They had proper bends and fit very well. The original tubes I bought from Classic Tube did not.
Old Apr 27, 2018 | 10:40 AM
TimAT's Avatar
TimAT
I got the "kit" for the L-88 from one of the big vendors. It fit like a saddle on a sow. I ended up making one from 3/8 tubing and a bunch of inverted flare nuts. Now, it's all hand bent with AN fittings.
Old Apr 27, 2018 | 11:00 AM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
You'll have to tweak fitment on any kit, my recommendation would be to NOT get any of the stainless lines. They are pretty tough to get a proper seal.
Old Apr 27, 2018 | 11:27 AM
3X2's Avatar
3X2
I'm on line #3. Bought a stainless line, leaked at the fuel pump, misfromed flare. Bought a steel line from another vendor, leaked at the fuel pump, misformed flare. Reinstalled the 49 year old original line, had to bend it to fit, no leaks. Bought another stainless line from private seller, flares looked good but seeped fuel at pump. Tighten the living **** out of fitting, so far, no leaks. But I'm going to replace it anyways. I don't want to wait for Corvette Carlisle to see one, in hand, before paying for it. I'm not having any luck finding an original GM 67 400/435 fuel line.
I thought there was some sort of bevel sealing washer to use between the two flares for situations like this. Goodridge sends them with their C6 brake lines. I can't find them for in the size I need.
Old Apr 27, 2018 | 11:28 AM
3X2's Avatar
3X2
Fitment isn't the problem. Fuel leakage is. It is a 69 435 car and I installed a 67 435 manifold.
Old Apr 27, 2018 | 11:36 AM
ddawson's Avatar
ddawson
I use the copper flare gaskets, Otherwise My connections would leak.
http://www.pontiactripower.com/shop/...516-fuel-lines
I bought mine from granger, https://www.grainger.com/category/fl...ecatalog/N-qw3
Old Apr 27, 2018 | 12:03 PM
Wee's Avatar
Wee
I got the one for my 72 SB from Jegs....It came in a box from a different vender and the line was marked from another vender. It was off by a couple of inches at the carb but was easy to bend and seal was not an issue. I will post a photo of the label tonight. I did use plain steel, I didn't want any part of the nightmare of trying to get S/S to not leak.
Brian
Old Apr 27, 2018 | 12:20 PM
Shovels and Vettes
I agree to avoid stainless lines on any tube that has a fitting. On my 77, the fuel lines are all attached with rubber hoses, so I used stainless on the fuel lines, and Tin Bundy original style on brake lines. No leaks, and everything fit very well with only very minor adjustments.....on the tubes from Inline Tube. The Classic Tube lines were WAY off and I lost a lot of money shipping them back i.e. shipping charges were not credited.
Note: I had Inline Tube bend me a custom fuel line from pump to Quadrajet....because I used an Edlebrock RPM intake that sits about an inch higher than stock....so they simply provided a custom line that was about an inch taller. Fit perfectly, no leaks. Tin Bundy , not stainless..
Old Apr 27, 2018 | 01:39 PM
Tim69L46's Avatar
Tim69L46
I've got a set from Zips for my L46 SB arriving today. The brake lines I bought from them fit great so I figured I give them a shot. I'm using steel same as the originals and as noted above they are easier to tweak. I expect that I won't have to worry about the new ones the old ones lasted 49 years with vise grip damaged nuts and weld repaired tubing. I'll let you know how they fit.
Old Apr 27, 2018 | 02:37 PM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
I bought the ss lines off ebay from SS Tubes. They leaked like a sieve. Went to rubber hose for now.
Old Apr 27, 2018 | 03:39 PM
tyrant's Avatar
tyrant
I bought stainless from Corvette America. No issues to speak of. Easy install with the frame off.
Old Apr 27, 2018 | 05:09 PM
3X2's Avatar
3X2
Thanks for all the replies. Looks like I'm going with inline tube.
Old Apr 27, 2018 | 08:44 PM
Wee's Avatar
Wee
Here is the label
Brian
Old Apr 28, 2018 | 09:03 PM
Tim69L46's Avatar
Tim69L46
3X2 here are some pix , I installed the ones I got from Zip today, Nicely double flared no leaks. They did need some tweaking they are steel and adjusted fine it would have been real difficult if they were SS. Here are some pictures of the pump to filter, filter to carb and bypass pipes. Make sure you get the clip that ties the vent line to the pump to filter line. Tim
Old Apr 29, 2018 | 06:54 AM
3X2's Avatar
3X2
Looks good Tim. I have a 427 tri power, so there is no filter or return line.
Old Apr 29, 2018 | 07:44 AM
Tim69L46's Avatar
Tim69L46
Thanks. I Kinda figured that may be the case. Most complaints were about flares, leaking and fitment so while different I thought I'd send some feedback on those issues since the SB has a few more bends and parts involved.
To whose fuel line to get?
