fuel injection temp fix
Old Apr 28, 2018 | 11:45 AM
Tonycabler's Avatar
Tonycabler
4th Gear
Default fuel injection temp fix
Hey all,
I just broke a valve spring. After removing the broken pieces and opposite push rod, rocker arms, guide plate and studs. oh, and taking the tappets out, does anyone see a problem disconnecting the injector, removing and plugging the spark plug hole and removing the spark plug wire just to limp it home? (200 miles)
Old Apr 28, 2018 | 11:50 AM
Tonycabler's Avatar
Tonycabler
4th Gear
Default more...
The valve is bent and stuck in the closed position...the other is ok and intact.
Old Apr 28, 2018 | 11:58 AM
v2racing's Avatar
v2racing
Only if you don't care if the engine is trashed by the time you get it home.
Mike
Old Apr 28, 2018 | 01:39 PM
Tonycabler's Avatar
Tonycabler
4th Gear
Mike
How would it get "trashed" ??
Old Apr 28, 2018 | 04:35 PM
TimAT's Avatar
TimAT
Without the lifter (tappet) in place, no oil pressure to the engine forward of that point. IT will be a massive internal leak.
Old Apr 28, 2018 | 09:30 PM
derekderek's Avatar
derekderek
Leave lifters in and they could be shot out by the cam. Would have no oil pressure. Same as with removing lifter. Tow it.
To fuel injection temp fix
