Engine Bay Cleaning
Old Apr 28, 2018 | 01:06 PM
spanky13's Avatar
spanky13
Default Engine Bay Cleaning
Hello,
1. what is everyone using to clean the engine bay no need for the harsh chemicals as it will eat away most rubber, hoses, spark plug wires/caps etc?
2. best way to clean the rust on the brake power booster?
Thanks for the help
Old Apr 28, 2018 | 09:34 PM
drwet's Avatar
drwet
GM Engine Shampoo is the best product I have found. Only real solution to the rust on the brake booster is to have it rebuilt and replated. Paint is a decent fix if original finish isn't important to you.
Old Apr 29, 2018 | 06:49 AM
Alan 71's Avatar
Alan 71
Hi s,
"(2.)".....
Depending on the year of the car the brake booster may have been painted gloss black and not plated. This makes restoring a rusted booster a bit more straight forward.
To restore the appearance of a rusted booster I'd remove as much rust as possible by hand, then use wire brushes, and finally a paste type rust remover.
Then the booster can be painted gloss black, or if the booster was originally di-chromate washed zinc plating, painted with one of the paints that mimics the plated appearance, or send it off to be re-plated.
Regards,
Alan
I don't think there's any 'magic' to cleaning the engine compartment... it takes work, work, work.....time, time, time.
Old Apr 29, 2018 | 09:33 AM
drwet's Avatar
drwet
Originally Posted by Alan 71
Hi s,
"(2.)".....
Regards,
Alan
Don't listen to him. Alan 71 has clearly sold his soul to the devil in return for his car staying perpetually clean. Its the only possible explanation.
Old Apr 29, 2018 | 10:07 AM
spanky13's Avatar
spanky13
Hi s,
"(2.)".....
Regards,
Alan
car is 1977 with approximatlely 32,000 miles Iam the 2nd owner so I don't know if what is on the car the factory installed booster or if the previous owner had it replaced which I do not think so due to the milage on the car when I purchased it, but I could be wrong and anything is possible.
Thanks for the help
Old Apr 29, 2018 | 10:09 AM
spanky13's Avatar
spanky13
Thanks for the help drwet
Old Apr 29, 2018 | 11:42 AM
Alan 71's Avatar
Alan 71
Hi,
I believe 77 cars typically had a booster that was originally plated.
So if you don't want to get involved with having the booster re-plated painting it with a gold/copper colored paint is a nice option.
Regards,
Alan
Here's an example of a part that was originally plated with an attempt to mimic the appearance of the plating using paint.
Old Apr 29, 2018 | 10:02 PM
BLUE1972's Avatar
BLUE1972
I use Dawn DISH DETERGENT and water to clean the engine compartment. It works well. It will remove most oils and grease so be careful after a good wash.
On my classic truck I used Simple Green diluted a lot. It also works well and will remove most dirt and grease.
Depending on which car wax you use they can remove the car wax.
Old Apr 30, 2018 | 11:58 AM
stingr69's Avatar
stingr69
I like the diluted simple green as it seems pretty gentile to original finishes while still getting the grunge off.
Old Apr 30, 2018 | 12:17 PM
jim-81's Avatar
jim-81
yes
Old Apr 30, 2018 | 09:32 PM
general ike's Avatar
general ike
2017 C3 of the Year Finalist
St. Jude Donor '20- '21
Alan please tell me this is not true!!!!! Ike
Old Apr 30, 2018 | 10:59 PM
3JsVette's Avatar
3JsVette
Me too. Never harsh and cleans most anything.
To Engine Bay Cleaning
