C3 Frame dent repair tool
Old Apr 30, 2018 | 08:36 PM
68Rick's Avatar
68Rick
Default C3 Frame dent repair tool
does anyone know where i can purchase a used or new frame cross member dent repair tool? I would rather purchase used since we would only use this tool only once. (hopefully)
Old Apr 30, 2018 | 09:12 PM
EarlyC34me's Avatar
EarlyC34me
Parts Sherpa
Send tfringo a pm. His name is Terry he designed the tool
Old Apr 30, 2018 | 11:16 PM
CanadaGrant's Avatar
CanadaGrant
There is one of his crossmember dent removal tools floating around here among forum members where you just pay the shipping then send it off to the next guy after use. Try a "who has the pay it forward cross member dent removal tool" post.
Old May 1, 2018 | 07:05 AM
Alan 71's Avatar
Alan 71
Hi Rick,
I believe this may be the most recent thread about one of the 'dent' tools.
Mooser made this one and it got passed around a bit.
You might check with Bill to see if he still has it or if it went to someone else.
Regards,
Alan
https://www.corvetteforum.com/forums...dent-tool.html
Old May 1, 2018 | 02:55 PM
Gold Dragon's Avatar
Gold Dragon
Followed the link posted by Alan. There are no pictures of the tool. I would like to fabricate my own, if it is possible. Does anyone have a photo of this elusive tool.?
Ray
Old May 1, 2018 | 03:00 PM
MelWff's Avatar
MelWff
a general description is two curved thick metal plates with a threaded hole in the center. One piece slides into the cross member where the lower control arm is mounted after you remove it and the other piece is on the out side. They are both centered on the hole in the center of the cross member and then a large bolt is inserted through the both of them and tightened acting as a press to force the cross member into the curvature of the two plates.
Old May 1, 2018 | 03:29 PM
Alan 71's Avatar
Alan 71
Hi Ray,
Here's a photo of the tool's parts.
Regards,
Alan
The arched plate has a large nut welded to it and is inserted into the front crossmember.
The 'bridge' is held up against the crossmember and the bolt is threaded into the plate through the hole as MW described.
I found it took a good bit of effort and work to get decent results.
Old May 1, 2018 | 05:37 PM
Mooser's Avatar
Mooser
Ray
https://www.corvetteforum.com/forums...mber-dent.html
I've no idea where this tool currently is
M
Old May 1, 2018 | 07:53 PM
1974ta's Avatar
1974ta
Default Dent Tool
I am pretty sure I sent it to someone in New Jersey not that long ago.
It was definitely someone on this forum just cannot remember who.
Kind regards,
Bill
Old May 1, 2018 | 07:55 PM
1974ta's Avatar
1974ta
Default Dent Removal Tool
I sent it to Rayhawk here on the forum.
Maybe you can shoot him a PM to see if he knows of the tools whereabouts.
Kind Regards,
Bill
Old May 2, 2018 | 11:27 AM
68Rick's Avatar
68Rick
Default Thanks
thanks to you all. I have one on the way and I’m looking fwd to getting rid of my dent.
Old May 3, 2018 | 06:49 PM
mardyn's Avatar
mardyn
My front cross member needs some attention as well... subscribing
Mardyn
Old May 4, 2018 | 10:32 PM
Norm07's Avatar
Norm07
Kind Regards,
Bill
Rayhawk has has it right now, just waiting for him to finish with it...
Old May 5, 2018 | 08:56 PM
Mooser's Avatar
Mooser
So it's making it's way back up here to Ontario
Let me know when it makes it to you
M
Old May 8, 2018 | 01:37 AM
68Rick's Avatar
68Rick
thanks for the info. I sent Terry a PM and and found what i needed. What a great fella to do business with.
Old Mar 11, 2019 | 07:23 PM
Mooser's Avatar
Mooser
Hi Norm
Wondering if my tool ever made it up to you?
M
Old Mar 11, 2019 | 09:25 PM
Norm07's Avatar
Norm07
Mooser....Never made it here....sent you a PM
Old Mar 11, 2019 | 10:11 PM
Mooser's Avatar
Mooser
Thanks Norm
It tends to do that (disappear for random lengths of time), I was hoping to get it back eventually
M
To C3 Frame dent repair tool
