Speedometer is off by 15 mph
Old Apr 30, 2018 | 09:00 PM
JillsVette's Avatar
JillsVette
Default Speedometer is off by 15 mph
So the 77 is on the road and running fine. The speedo is off by about 10 - 15 mph.
it has an orange drive gear on the trans output shaft and a 19 tooth white driven gear on the speedo adapter. I have an extra gray 21 tooth gear. Would that be enough to drop my mph 10 - 15?
Old Apr 30, 2018 | 09:03 PM
zwede's Avatar
zwede
It will lower the indicated speed by 10%
Old May 1, 2018 | 08:25 AM
JillsVette's Avatar
JillsVette
Default speedo
I recounted the teeth again and it is 22. I'll give it a shot to see how close we get. Im pretty sure the next gear change would entail replacing the drive gear on the output shaft. Jill may just have live with the results for awhile... Thank you for the info.
​​​​​​​Matt
Old May 1, 2018 | 09:12 AM
drwet's Avatar
drwet
It depends on how fast you're driving. If you're driving at 10 mph and the speedo reads 25, you're out by 150% and the gear you have won't help much. If you're driving 75 and the speedo reads 90, you're out by 20% and the gear you have would be about perfect.
Old May 2, 2018 | 07:39 AM
LenWoodruff's Avatar
LenWoodruff
For years I used the Tach to tell me my speed. I have 3:55 rear gears and the speed was the tach times 2. So 60 mph was 3000 rpm.
Old May 2, 2018 | 11:45 AM
7T1vette's Avatar
7T1vette
Three more teeth might get you 10 mph lower at highway speeds. It should be close at city speeds (>5 mph lower than actual).
Old May 2, 2018 | 06:03 PM
derekderek's Avatar
derekderek
Reading high or low? Reading low could be speedo magnet getting weak. Nothing to do with gear ratios.
Old May 3, 2018 | 12:06 AM
7T1vette's Avatar
7T1vette
That's also a possibility. More info is needed on car's history to determine which is more likely. In any event, if the speedo has been 'consistent' for a significant period of time, the issue can either be "corrected" or "masked" by changing the speedo drive gear.
Old May 16, 2018 | 12:01 PM
JillsVette's Avatar
JillsVette
Default Speedo Fixed
Finally had some time to get the 77 Vette off the ground and change the speedo driven gear. Swapped out the 19 tooth for a 22 tooth gray gear and the speedo dropped about 13 mph. It is very close to where it needs to be so Im going to call it fixed. Thank you to all who offered help, we can all this case closed.
Matt
To Speedometer is off by 15 mph
