Black window trim
Old May 6, 2018 | 09:31 AM
hotrodnick's Avatar
hotrodnick
Default Black window trim
Any ideas on what black to use on 79 window trim. One supplier uses DupliColor but I can't determine what finish it is.
Old May 6, 2018 | 11:45 AM
Street Rat's Avatar
Street Rat
My '81 has gloss black mldgs.
They may not have the correct color black though.
My color code is 19.
Craig
Old May 6, 2018 | 12:17 PM
A88FXRS's Avatar
A88FXRS
SEM Co makes the exact color for moldings. might be called satin black in an aerosol can. used it many times
Old May 6, 2018 | 12:41 PM
Lakeside49's Avatar
Lakeside49
Agree - this is the best, and correct paint:
Old May 6, 2018 | 12:43 PM
Lakeside49's Avatar
Lakeside49
In case the photo did not come through using my cell phone, the SEM black trim paint (rattle can) is: #39143
Old May 6, 2018 | 02:38 PM
DUB's Avatar
DUB
For what this is worth:
I repaint this molding quite often on many Corvettes.
I generally remove the molding and If there are areas where the paint has completely popped off and I am looking at the aluminum trim. I strip all of the paint off and then I apply an etch primer from SEM...then the satin black.
Now you can just go in and paint it...but in time...from what I have found. That if an etch primer is not sued... the paint can pop back off.
DUB
Old May 6, 2018 | 02:45 PM
revitup's Avatar
revitup
Painted the trim on my '77 with VHT satin Bumper and Trim paint. The match was very nice. Sanded lightly and primed first. It's held up perfect (except of course where I had to promptly scratch it with a T-top). No need to remove the molding, you can easily mask around it.
Old May 6, 2018 | 03:03 PM
DUB's Avatar
DUB
I agree the front windshield can be done when it is on the car depending on the level of quality a person desires.
But this thread is dealing with the back window trim..and the amount of time it would take to mask it of and have it look half way decent. I can have the trim off an stripped.
Once again...it all depends on what a person is expecting.
DUB
Old May 6, 2018 | 07:32 PM
Wrecked82's Avatar
Wrecked82
I have the tool to pop off the rear trim, but so, so long that I used it that I am hesitant to try it to remove trim. Remember probably a decade ago, I did remove trim, repainted with plain old satin flat black and has looked good since. One or two very minor spots showing aluminum underneath. Will probably use a fine paint brush with a pointed tip and touch up soon.
Old May 6, 2018 | 08:01 PM
av81's Avatar
av81
VHT makes a satin finish paint that looks correct , Advance Auto parts sells it .. I agree on removing the rear molding to repaint it , it pops right off with the tool.
To Black window trim
