Window closing problem.
Old May 14, 2018 | 01:05 AM
jhopper408's Avatar
jhopper408
Default Window closing problem.
I put new rubber seal's on the front pillars. You know where the windows should seal. But you can only roll them up completely with the door shut. Then you can't open the door with out rolling the window down about one inch. What have I done wrong??
John.
Old May 14, 2018 | 11:15 PM
general ike's Avatar
general ike
2017 C3 of the Year Finalist
St. Jude Donor '20- '21
John, I have the same issue, so I am watching your post carefully. I have a feeling that we may need to realign the window to correct this. Ike
Old May 15, 2018 | 12:11 AM
jhopper408's Avatar
jhopper408
Hey ike. Boy that's great. We can keep each other informed
Thanks John.
Old May 16, 2018 | 12:40 PM
Street Rat's Avatar
Street Rat
John.
Hey John what year is your vehicle?
I have done this on my '81 twice. The second time I learned that the A pillar ws moulding was adjustable. I could move the moulding in and out to adjust the ws contact area. Hopefully this is the case with yours. You shouldn't have to readjust the window unless the ws was glued too far down or up in the moulding.
My .02
Craig
Old May 16, 2018 | 06:48 PM
DUB's Avatar
DUB
SO..IF I am reading this correctly. IF you rolled your door glass all the way up and tried to close the door you would have a problem???
When the door glass is up all the way...and your door is OPEN. Does the door glass move in and out and have play in it and it not being solidly held in an angled position??? This is IMPORTANT!
Does it seem that your glass is wanting to hang up on the blow out clips when you attempt to open the door with the door glass up and the door is closed???
DUB
To Window closing problem.
