Electrical Connector Replacements
Old May 23, 2018 | 07:27 AM
haarvik's Avatar
haarvik
Default Electrical Connector Replacements
Is there a way to find out what part number a specific connector is? I need to replace the connectors that go down to the starter. The female side has started cracking apart.
TIA
Old May 23, 2018 | 07:57 AM
bmotojoe's Avatar
bmotojoe
TIA
You can scroll through some of these pages, Delphi/Packard series 56. When they describe M/FM connector they are describing the actual crimp terminal. A male connector will not except a FM terminal.
https://www.ebay.com/sch/i.html?_fro...&_odkw=7984415
Old May 23, 2018 | 09:49 AM
haarvik's Avatar
haarvik
None of those are it. The connector has eight wires on it and is located by the passenger side heater blower motor housing. The feed side is white, and the starter side is black.
Old May 23, 2018 | 09:57 AM
haarvik's Avatar
haarvik
The image at the top of this post shows the side going to the starter. I need the one that it plugs into.
https://www.corvetteforum.com/forums...er-wiring.html
Old May 23, 2018 | 10:51 AM
bmotojoe's Avatar
bmotojoe
Any of these?
https://www.mouser.com/Aptiv/Connect...z0zlezZ1yvgcdj
Old May 23, 2018 | 11:29 AM
haarvik's Avatar
haarvik
Sweet. Looks like those may work. Probably should swap out both sides just so I know they are both good. Guess I need to bookmark that site! Thanks!
To Electrical Connector Replacements
