Leaking t top
Old Jul 1, 2018 | 12:57 PM
Joker66's Avatar
Joker66
Cruising
Default Leaking t top
I have a 1979 Corvette .the passenger side t top leaks at the back corner by the window. I purchased a new set of t top seals from corvette America. But it still leaks. was considering getting a new set of tops. Or possibly a one piece . Is there anything I can do besides replacing the seals to fix the leak.
Old Jul 1, 2018 | 11:09 PM
kingkohlmn's Avatar
kingkohlmn
Veteran: Marine Corps
Are you sure the is sealing?
Old Jul 1, 2018 | 11:11 PM
kingkohlmn's Avatar
kingkohlmn
Are you sure the window is sealing? Water may getting in there.
Old Jul 2, 2018 | 02:59 AM
AB_in_AUS's Avatar
AB_in_AUS
Your window may not be aligned correctly with the T-top seal and the pillar seal. I had to adjust my windows to get them to seal correctly after fitting new T-Tops
To Leaking t top
