Intake bolts
Old Jul 2, 2018 | 05:35 AM
croaker's Avatar
croaker
Default Intake bolts
Reinstalling a Elderbrock intake and I'd like to install washers. A different style bolt with a smaller head also. Most bolts in intake kits are only 1" which is a bit short I believe. Will the 1" be enough? The ones I removed are 1.25 SS with a regular hex head. A few are almost impossible to get torqued down.
Old Jul 2, 2018 | 07:04 AM
derekderek's Avatar
derekderek
Regular hardware store stuff is 1 and 1.5 inch. Most will have Allen head also. You want 12-point you need to find a fastener place. Another option is buy longer, thread nut on the bolt, and cut it to exact length you want. Removing nut cleans up the end of the thread. Aftermarket intake implies originality isn't your first priority. Standard cheap hardware store bolts are just fine for intake manifolds, carbs, etc. DON'T use them in connecting rods and flywheels...
Old Jul 2, 2018 | 02:51 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
the minimum requirement is that the depth of the threads into the block in this case be greater then the diameter of the bolt for getting the strength you need. you can cut the longer threads off with a cut off wheel just jamb two nuts together where you want it to be terminated and then use a cut off wheel to cut the bolt....the threads will be intact and its cut to length, I think the round serrated allen head bolts look really cool
Old Jul 2, 2018 | 03:33 PM
68/BB's Avatar
68/BB
I used a factory intake on my BB (3933163) but I used ARP bolts.
Old Jul 2, 2018 | 03:56 PM
bobs77vet's Avatar
bobs77vet
those are sweet looking
Old Jul 2, 2018 | 04:40 PM
7T1vette's Avatar
7T1vette
Those appear to be flanged-head bolts. What's the purpose of the added washer?
Old Jul 3, 2018 | 01:11 AM
croaker's Avatar
croaker
Those ARP are pretty and pricey. I'm needing something with a washer and a smaller head one in particular is nearly impossible to tighten when snugged up. I've seen kits like I want but only 1 inch in length. I was just wondering what others are using in this situation
Old Jul 3, 2018 | 07:22 AM
derekderek's Avatar
derekderek
Buy a single Allen head bolt for the hard one. Or 12...
Old Jul 3, 2018 | 08:17 AM
croaker's Avatar
croaker
I've considered that. I'm thinking something made like a flange bolt. The bolts I have now are gouging the intake.
Old Jul 3, 2018 | 08:33 AM
derekderek's Avatar
derekderek
A good flat washer under them. If too big diameter. Bolt washer to a 3/8 bolt. Chuck bolt in a drill. Fire up a grinder. Bench, makita 4-1/2, whatever.spin washer and put it against the grind wheel. Not a real precise surface grinder, but it'll make a washer the size you want.
Old Jul 3, 2018 | 11:29 AM
68/BB's Avatar
68/BB
They came in the set from ARP so I used them.
Old Jul 3, 2018 | 11:44 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Originally Posted by bobs77vet
.I think the round serrated allen head bolts look really cool
That's what I use and they do look nice. Easier to tighten also.
Old Jul 3, 2018 | 11:54 AM
sstonebreaker's Avatar
sstonebreaker
What about these? Summit
Old Jul 3, 2018 | 11:59 AM
Tonio's Avatar
Tonio
Edelbrock......
Old Jul 3, 2018 | 12:52 PM
gungatim's Avatar
gungatim
I like the smaller heads with a washer like Summit sells. they usually come in a kit. the edelbrocks and other aftermarket intakes have larger holes than stock, I assume for variation in head angle if they've been milled or block decked, at least that's my theory. factory bolts don't tend to work as well without a washer and those middle ones are a pain to tighten unless you get a reduced head or allen head style.
don't forget sealant so they don't weep oil.
Old Jul 3, 2018 | 01:17 PM
7T1vette's Avatar
7T1vette
68/BB...
Are those just split-lock washers? If so, that makes sense. From the photo, it looks like they are just flat washers, which made no sense to me.
[Split washers will keep the bolt in place; flat washers in that application would do nothing for the joint.]
Old Jul 3, 2018 | 05:28 PM
croaker's Avatar
croaker
From the reviews only 3/4"
To Intake bolts
Old Jul 3, 2018 | 05:59 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
To get a proper cinch without digging into the intake metal......the "flange" bolt is not really such.......it is just a smaller head for extra access in tight areas.......
BTW......these stainless ARP intake bolts are the only ones I will use......they are mandatory on a lower singe plane intake.......no way to get a wrench on normal bolt.
Oh.....and make sure you use a little PTFE on the bolts too for the ones that are not blind......
Jebby
Old Jul 3, 2018 | 06:04 PM
68/BB's Avatar
68/BB
Jebby
Agree. They increase the surface area and I assume they help prevent galling of the aluminum at the torque surface. They are not split BTW. I used ARP studs or bolts thru out the assembly on my BB. Probably overkill but not really a major cost difference in the big scheme of things, IMHO.
Old Jul 3, 2018 | 06:25 PM
derekderek's Avatar
derekderek
Ptfe? Rtv?
