Booster / brake pedal travel
Hi All,
Hoping someone can help me out here. I replaced my brake booster in my 1978 corvette. Now my brake pedal travel is too much and I have to raise my foot up six inches in order to hit the brake pedal. I made a spacer to go between booster and firewall to move the booster closer to the front of the car and it helps but brings on a whole bunch of other problems and i don't want to drive or sell the car with that mod. I need to replace the booster with different one so gas and brake pedals are the same. Problem is I don't know what booster i should order. What would I tell the parts person, oh i need one that is ???? Anybody have any idea?
Nam Labrat
Received 4,203 Likes
Hi All,
Wait for experienced Members to give you better information.
Did you verify that the actuator pin (booster to master cylinder) is the correct length for the new parts you installed? It must be the SAME LENGTH as the depth of the space it has to fill. If it is too short, your pedal travel will be gone before the M/C ever starts to actuate. Also, you can connect the booster at more than one location on the brake pedal. Make sure it is assembled at the correct location.
Nam Labrat
Funny thing is when i swapped out the old for the new I saw that the plunger attachment on the new was different than the old one. Did not worry about it figured it would fit same as old one. Also yes there is a built in stop but my pedal only has one hole not two. I guess there was more than one available back in 1978?
Sorry I don't have better advice.
Nam Labrat
If your new booster has a hex head adjusting screw on the tip of the rod, sometimes the edges of the hex head will interfere when inserted into the master cylinder plunger. I recently had that problem and had to grind the hex corners off so the tip of the adjusting screw would fit all the way into the m/c plunger. Then I was able to accurately adjust the rod so the m/c would fit against the booster without being in a bind.
