Radiator flush
For a 1975 C3, install a 180*F thermostat...unless you live in a super-scrutinous emissions control state. Then, you will need to have all the stock equipment installed; and I assume that means the same thermostat (emissions are reduced by running the engine hotter at idle) which was a 195*F item.
P.S. The 195*F stat will probably not cause your engine to run much warmer than the 180*F stat, unless you have upgraded your radiator to increase cooling capacity of the system. But, Chevy engineers decided that a 180*F stat was optimal when the V8 was born in the mid-50's; and the reason the stat temp changed was purely due to EPA regulations. Hence, my suggestion...
