C3 temperature sender
Old Aug 11, 2018 | 06:25 PM
mbp's Avatar
mbp
Default C3 temperature sender
Hi again. still working on temp. gauge. I have been trying to get an accurate reading on my temperature gauge, 69 SB and not original gauge or sending unit. I am reading about 40 ohms. high according to the Willcox numbers for the 180 degree temp ( first mark on gauge). Tested a few different sending units and they were consistent but the ohms were all high and would give a false low temperature. Verified with an I.R. gun. This seems to be the case for aftermarket senders and gauges.
What I would like to know or explained to me is why the adjustable resistor that is available not able to be hooked up to a replacement gauge so that the ohms between the sending unit and gauge can't be adjusted for what the ohms should be that the gauge needs to receive for an accurate reading. Hope this makes sense.The fact that their seems to be no way to get an accurate reading seems hard to believe. Thanks and take care.
Old Aug 11, 2018 | 06:49 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Wow.. this is the easiest answer I've had all week...
Okay, on the original gauges the resistor is external, on the reproduction gauges, when you install them they come with a plastic spacer and the resistance is on the inside of the gauge. So if you add our adjustable resistor to the gauge you'll double up on the resistance and the gauge will not function. Why they made the imported reproduction gauges with the resistance on the inside... I have no clue... When the adjustable resistor is installed on a factory gauge you are making a linear change to a non linear gauge, but when you already have resistance in the gauge this is pretty much impossible. I suppose in the future I'll take a look at a possible solution but for now the resistors fly off the shelf as fast as we can make them.
Willcox
Old Aug 11, 2018 | 10:06 PM
mbp's Avatar
mbp
Willcox
Thank you for the very quick reply. Now I understand. Just have to make do and use it as is. At least it works and I'm able to keep an eye on it to monitor any high temps. Thank you again!
Old Aug 12, 2018 | 06:42 AM
7T1vette's Avatar
7T1vette
Why do you care that the temp gauge is not at all accurate at "low temps"? There is only one reason to look at the temp gauge: to see if the engine is operating at its 'normal' temperature (what you usually see when the engine is fully warmed up). If it is at normal position, all is good. If the temp is above normal, there's a problem.
I don't know of anyone who watches the temp gauge when the car is cold. When testing for a cooling system issue, one could watch the gauges transition from 'cold' to 'hot'; but I've never considered the temp gauge to be an accurate device. It's merely a tool used to observe for unexpected temp changes.
To C3 temperature sender
